Shadows On Ceiling - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-03-2010, 12:44 PM   #1
Shadows on ceiling
Iíve noticed shadows on my ceiling that follow the roof trusses. I checked the attic and didnít see any mold or leaks. The paint on the ceiling is pretty old, but why would the shadows be following the trusses?
in2flyfishing is offline   Reply With Quote
Old 04-03-2010, 01:01 PM   #2
Pictures would help..
odds are you are reading for the firstime ... seams and naiing pattern of drywall compound on nails. Many factors could make this show up.. temperature variance ... etc...
prime and paint again for best chance for these "shadows" to go away.
Big Bob is offline   Reply With Quote
Old 04-03-2010, 02:02 PM   #3
Ceiling
Thanks Big Bob.
It's a little hard to see but from the picture you can see the shadows follow the 24in spacing for the trusses.
Old 04-03-2010, 02:45 PM   #4
A++ picture.
how old is the ceiling? Code changes in FL addressed the 24" OC problem your pics show by calling for 5/8" rock on ceilings then... Later USG and others came out with re-inforced ceiling rock.. in-between... drywallers reinforced the back of the boards with duct tape...
this may be a time and humidity thing.. catching up to you.
painting won't solve this...
TEXTURE LOOKs LIKE ORANGEPEEL or light single knockdown: Solution might be 1. scape texture. 2.damp wipe clean.. heavy skim coat.. texture as desired...3. repaint if needed.
or better ...long term... R&R or rock over with 5/8" or ceiling board .. prime and retexture.. paint if needed.
You are not alone with this look... many..many.. houses have the same appearance.
Old 04-03-2010, 02:59 PM   #5
Ceiling
It's 18 years old. Live in the Seattle area. Hope a new coat of paint will take care of it
Old 04-03-2010, 03:11 PM   #6
Seattle is know for it's good football team and being rather rainey...= humidity.
Paint will work if you really believe it.. wear sunglasses inside.. and change the lighting... I will take my 5 yr old grand daughter on the polar express again this year...and we will believe...believe...believe...
Old 04-04-2010, 01:22 AM   #7
sounds like drywall sag
beerdog is offline   Reply With Quote
Old 04-04-2010, 08:28 PM   #8
Registered User
Rewards Points: 4,912
Howdy from Tacoma!
http://www.buildingpreservation.com/Case%205.htm
Be safe, Gary
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 05:18 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
