Setting Posts For Pole Building - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-12-2009, 03:50 PM   #1
setting posts for pole building
Hi, i'm new to forum and i'm hoping someone can help me out with some info , or if someone has run into this. I'm building a 30 x 48 pole building which i will be using 6x6 pt posts , well i drilled my holes to set my posts in and after 1 day i had about 3 ft of standing water in them, now my building dept wants me to put 2 bags of concrete in the bottom of each hole as a footing . The problem is i don't know if the concrete will set up in the standing water or not , and i'm also a little worried that if the water table is that high for 9 mos. out of the year how long are my posts going to last. Any advice is greatly appreciated.
2wheelerbill is offline   Reply With Quote
Old 04-12-2009, 08:07 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 650
Ayuh,... Concrete will set up underwater, No Problem....
I'd probably pour piers in sonnatubes,+ bolt the wood to at-grade concrete footers
Bondo is online now   Reply With Quote
Old 04-12-2009, 08:13 PM   #3
Civil Engineer
Rewards Points: 4,572
Concrete will set up under water, as noted in the previous post. However, you should tell the concrete supply company that you planning to place the concrete under water, they will bring a truck with the proper mix.
Since you are building a pole building, you should consider using one concrete footing (in a sonotube, as previously recommended) per pole. I would bring the footing at least six inches above grade, and use a commercial bolt on plate (Simpson makes one, so do other companies) to attach the 6x6 PT pole to each footing. Check with the building department first, they may have requirements about the type of connector they need to see.
help settling porch posts - a dilemma. wombosi Carpentry 9 10-10-2008 01:01 AM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
Cracks in pressure treated posts (4x4s, 6x6s) Deck Building & Construction 8 05-15-2008 11:57 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
