Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-18-2011, 11:25 AM   #1
septic pump
I had water backing into my basement yesterday and opened my septic tank and found that my filter was dirty. Cleaned it and I'm all good now. However, before I opened the tank, I accidentally opened my pump chamber. The pump was running, which is fine, but I noticed some water spraying out of the pipe that leads from the pump to the septic tank. It was bigger than a pin hole, but not as big as a hose spraying. I wasn't sure if that's by design (some sort of pressure release) or what. I assume it's pvc, so thought it would be unusual for it leak like that (a hole just suddenly appearing). Anyone know if this is by design or if I shoukd be calling someone?
ctbooch is offline   Reply With Quote
Old 12-18-2011, 12:11 PM   #2
Electrical Contractor
septic pump
The few I have seen had a hole in the pipe.
It allows the water to drain off before the pump starts up.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
The Following User Says Thank You to jbfan For This Useful Post:
ctbooch (12-18-2011)
Old 12-18-2011, 02:12 PM   #3
septic pump
Appreciate the response
Old 01-01-2012, 11:11 PM   #4
Scottphys's Avatar
septic pump
I had a similar situation. Two chamber tank, the pumping chamber contains a biotube assembly (PVC components) pu,ping to an uphill leach field. The pump comes on and sprays a fine mist In the tank. When the pump is off the transfer tuber backflows and drips into the effluent chamber. The components were just barely threaded together. I just went to town tightening the line components by hand. I didn't want five gallons of effluent coming back just to be pumped again.
I later added a elapsed time timer and counter for how long it runs. Wish I installed these before to quantify the effect.
Scottphys is offline   Reply With Quote
Good Pump For Septic - 70 horizontal feet JohnSlider Plumbing 2 01-03-2012 09:20 PM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 04:56 AM
Aerator pump size for septic tank spaceman spif Plumbing 9 03-17-2011 12:40 PM
Septic problem or vent problem? wilsonstark Plumbing 9 01-17-2011 07:35 PM
Sump Pump Questions henlij Plumbing 19 08-12-2009 08:50 PM
