Septic Inspection Cap - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-06-2013, 12:37 PM   #1
Septic inspection cap
My specific system is 20 years old. It works fine, however the cap will not screw into the cast iron inspection. The threads on the pipe are corroded. I tried cleaning the threads out wit a brush, awl and screwdriver. No Luck. The real fix is kind of expensive, my septic guy said forget it really isn't worth it and just caulk it. Caulk just not very effective.
I just ordered a a rubber cap (hoping it fits) for the time being. My other thought was grinding the pipe off under the cap hub, using a rubber coupling to PVC pipe with screw cap. My concern here is methane and a sparking tool.
Any thoughts
Any suggestions
goodhur is offline   Reply With Quote
Old 11-06-2013, 01:39 PM   #2
Rewards Points: 6,652
Just use the rubber plug. As for Methane, there is not enough at that opening to cause a problem, let alone that you are outdoors. Otherwise, just use a Chain tool that is used for breaking Cast Iron piping.
Old 11-06-2013, 02:54 PM   #3
Thanks, I am going to use the plug in short term. I think renting the chain tool is definitely the better way to go (cleaner cut, safer).
Old 11-06-2013, 03:39 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 348
You can get a plug called "lead fit-all". It's threads will conform to your clean out threads.
Or cut the pipe of with the chain or grinder and use an adapter of your choice
Old 11-06-2013, 07:37 PM   #5
Originally Posted by TheEplumber
You can get a plug called "lead fit-all". It's threads will conform to your clean out threads. Or cut the pipe of with the chain or grinder and use an adapter of your choice
Interesting. Are these fit-all's something I should replace every couple years when the pump out the tank?
Old 11-06-2013, 07:55 PM   #6
Plumber
Rewards Points: 348
Only if they get damaged too bad
Old 11-06-2013, 10:15 PM   #7
Thanks E that looks like like a way for me to keep it simple.
BTW the old cap measures ~5-1/2" across, do the sizes run nominal or actual (they look well tapered)?
Old 11-07-2013, 12:27 AM   #8
Plumber
Rewards Points: 348
Thats big- probably do a good google search to find one or call a plumbing supply house in your area. Some plugs will fit a couple thread sizes - 4"-4.5" as an example.
The key is to make sure you still have some existing female threads for the plug to grab
Septic Inspection in Winter mrvt Plumbing 7 02-25-2011 09:13 PM
Septic problem or vent problem? wilsonstark Plumbing 9 01-17-2011 07:35 PM
septic tank problems. littles Plumbing 1 02-24-2010 10:30 PM
Septic Newbie Needs Advice flyboy Plumbing 5 04-06-2009 07:05 PM
40s home still on Septic Tank? Inspection? twilightcall Plumbing 4 01-11-2008 07:35 AM
