Self Leveling Cement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-26-2010, 01:04 AM   #1
Self Leveling cement
I have an enclosed patio, about 14' x 20' The slab was sloped for drainage, starting even with the house slab, and dropping about 1-1/2".
I'm planning to upgrade this to living space, and I need to level the floor, not because it's particularly noticeable, but because the low side is even with the exterior concrete deck, and even with the exterior drain, water sometimes 'flows in'. I don't trust just a raised sill to protect the future flooring.
Is there a self leveling cement, that can just be mixed and poured, that's good from 0" to 1-1/2"? I've never used any; it's always sounded "too good to be true" . The floor is painted, and I plan to grind it to bare cement.
Thanks...
Gary
Gary Sutherland is offline   Reply With Quote
Old 09-26-2010, 05:53 AM   #2
Rewards Points: 582
There are some self levelling floor screeds that can be poured over concrete floors. Here is an example of one type.
http://www.flo-screed.co.uk/flo-screed-video.htm
Resin screeds can also be used for very thin screeds.
http://www.ryebrook.co.uk/floor_screeds.htm
stuart45 is offline   Reply With Quote
The Following User Says Thank You to stuart45 For This Useful Post:
oh'mike (09-26-2010)
Old 09-26-2010, 06:50 AM   #3
Chicago, IL
Michael Thomas's Avatar
Originally Posted by Gary Sutherland View Post
I have an enclosed patio... I'm planning to upgrade this to living space, and I need to level the floor....
Something to keep in mind: once this becomes "living space" a whole different set of code requirements may (will, in the communities where I inspect, here in northern IL) apply, including the need for a foundation far more substantial than a patio slab.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 09-26-2010, 06:12 PM   #4
Michael:
Three of the four walls enclosing the space are exterior walls of the house, so I only have to deal with the footing of one wall. The lower three feet of the wall is 12" thick stone, so it may have a substantial footing.
Gary
Old 09-26-2010, 07:03 PM   #5
Old School
Willie T's Avatar
Michael:
Gary
What do you base this assumption upon?
Willie T
Old 09-27-2010, 07:40 AM   #6
What the city told me.
Gary
Drywall or studs first before self leveling cement sandoy1121 Flooring 0 07-26-2010 07:50 PM
self leveling cement questions gramps416 Flooring 0 07-05-2010 10:36 PM
Leveling cement -step down porch with rest of house Cathy2 Flooring 1 05-24-2009 06:15 PM
leveling cement before tile drewhart Flooring 7 11-09-2008 01:18 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
