Selecting Different Lumber Lengths - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-19-2009, 01:31 PM   #1
Rewards Points: 154
Selecting different lumber lengths
I am currently building a deck and as with most do it yourselfers, its taking me much longer than planned. The stacks of 2x10 PT dougfir have been sitting in the sun a while, shrinking, bending, warping, etc. The piles of 10footers are looking pretty bad. At least 5% might be ok for blocking. The 20 and 24 footers however still look beautiful. On my next load I'm inclined to order 20 footers and just cut them in half. The price per foot is the same. Are these longer boards cut from a better part of the tree?
ovahimba is offline   Reply With Quote
Old 08-19-2009, 01:47 PM   #2
I always order the longer wood & cut whenever possible
It's usually less $$ here
PT needs to be installed/nailed framed out ASAP IMO
I keep mine stacked/weighted down out of the sun until needed
Old 08-19-2009, 02:18 PM   #3
General Contractor
Longer boards are usually cut from heartwood. You should check the moisture content of the wood before you decide to install it. Usually it is better to let pressure treated wood dry out a bit if you can to avoid shrinkage post installation. I like to use boards with 8% to 12% or less moisture content whenever possible.
ARI001 is offline   Reply With Quote
Old 08-19-2009, 02:44 PM   #4
47_47's Avatar
Rewards Points: 58
My local yard carries kiln dried pt #1 (2x8 and wider) for about 15% more than the box stores #2 sponges.
47_47 is online now   Reply With Quote
removing treated lumber edging pacifier1er Landscaping & Lawn Care 3 07-02-2008 12:08 PM
Raised garden bed using PT lumber rjniles Landscaping & Lawn Care 12 06-24-2008 09:14 PM
Was my local lumber yard being straight with me? RolandOG Building & Construction 6 05-28-2008 01:00 PM
Framing lumber very hard?? handyflyer Remodeling 2 04-15-2007 10:44 PM
