Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-30-2007, 05:01 PM   #1
Default Second level / attic bathroom size
I have a bungalow style home and the upstairs has never been finished. My plan is to put in a full bathroom (likely over the first floor bathroom so the drains and pipes mesh) and finish the rest into a bedroom. I wish I had a drawing, but I'll try to explain..... two windows on opposite walls, the other two "walls" follow the slope of the roof until they are about 4 feet from the floor at which point I put a vertical wall/brace in. I need ideas on what "minimal" bathroom dimensions are, I have no idea!
The entire livable area up there is approx. 10'x30' and the staircase will come up into one corner. The 10' walls have 29" wide windows centered in them, so I'm hung up on where to put the wall of the bathroom.... should the window go in the bathroom or be a part of the main room? I'd really like to avoid cutting a hole in the exterior wall for another window!
I'm thinking a shower, sink, and toilet, but no bathtub. I already have a tub downstairs and I was thinking that just a shower would be less of an installation/support hassle. Any feedback on that idea?
moneymgmt is offline   Reply With Quote
Old 05-01-2007, 08:11 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Hi,
Yes, that is a tough arrangement for a 'smaller sized' bathroom, based on where the windows are. Can you place the bathroom somewhere else - with no window?
Minimum size for a bathroom is affected by the size of the shower (and door swing room), Toilet placement (not visible thru the open door), Size of the sink/vanity. And also allowing room for you bath entry door in-swing. Generally, I would not go smaller than 5' or 6' by 8'....
- Build Well -
Old 05-02-2007, 09:32 AM   #3
Thanks for your feedback; unfortunately the only way to put it somewhere w/o the window would be to put it in the middle of the room. Or, to one side of the existing window but then I'm butted into a corner against the roof slope.... that's what spurred my "minimum" size questions. I know toilets, showers, and sinks are all different sizes and I'll likely end up with a small pedistal sink or narrow cabinet, a smaller toilet, and just the shower (no tub). My other issue (aside from wall placement in correlation to the window) is where and how high to put the shower head.
More On This Topic
Decorating a bathroom with color can be tricky, especially in a rental unit where the tile and flooring is purposely left neutral. But you can bring color into a bathroom without hiring a contractor, taking on a major project or losing your security... Read More »
The bathroom is a notorious place for germs to grow and thrive. It's also a typical haven for mold, mildew and fungus of all kinds. The damp atmosphere and general lack of proper air circulation in most bathrooms are major contributors to this sorry... Read More »
You're thinking of replacing those old, worn out sliding shower doors with a new pivot-type of shower doors. There are lots of things to consider while selecting the right type of shower doors for your shower. Here's how to buy the right type of shower... Read More »
When it comes to a house flip, the bathroom is one of the most important rooms. For this reason, dedicate a nice chunk of your budget to the bathroom (most of the money will be returned to you in spades at closing). People often sacrifice other... Read More »
It's easy for a bathroom to begin looking dated over the months or years. It is a room built for utility that people often do not think much about and do not want to dedicate a lot of financial resources to, but there are ways of giving your bathroom a... Read More »
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 17 09-06-2008 02:59 PM
Size of whole house fan needed Doug Crf General Discussion 7 06-21-2008 11:47 PM
Bird Block Soffit replacement options? Heather WA Roofing 3 05-06-2007 07:58 PM
correct joist size for attic helpless handyman Building & Construction 1 07-06-2006 01:29 AM
Bathroom Remodeling Ideas and Products to Increase the Comfort doctorhouse Remodeling 2 12-22-2005 10:40 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
