Sealing Windows - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-09-2011, 08:44 PM   #1
Sealing windows
I have a few small gaps on the exterior of my house between the window frames and the bricks. I would like to seal these before winter, but I'm not sure what to use. I would use silicone, but I don't want that wet look. I want it to look like it never had to be fixed. I've seen a sort of mortar-in-a-tube at lowes before. Should I use that? Should I mix my own mortar and use that? Thanks in advance for your help!
jamesbobo is offline   Reply With Quote
Old 10-09-2011, 10:35 PM   #2
Rewards Points: 6,652
What do you mean by "Wet Look"? Anything you apply, will look dry within a couple of days.
Old 10-09-2011, 10:52 PM   #3
I put some silicone around an outlet cover on the brick and where the silicone dried, it has a darker, wet look. I'm just trying to avoid that if possible
Old 10-10-2011, 09:36 AM   #4
Still do not mean what you are say by that it looks wet. Anything that you apply is going to have a new look to it for a few weeks, until it cures fully.
Old 10-10-2011, 12:37 PM   #5
Msradell's Avatar
Rewards Points: 120
Silicone sealants normally have a very slick finish even after they are fully cured, I'm sure that's what he's talking about!
Standard caulking is available in several colors including gray. When it dries it has a matte finish which is probably what you're looking for. It stays flexible so it will move with expansion and contraction and would be used the best solution for your problems. Mortar dries rigid and would be more susceptible to cracking during the expansion and contraction closed by temperature changes.
Msradell is offline   Reply With Quote
Old 10-10-2011, 12:57 PM   #6
Rewards Points: 2,238
Find a place that has "OSI", "Quad" caulk in your area -
Color that you like -
Use that - not "Silicone".
Make sure the surfaces are clean and dry.
As stated above - don't use mortar.
rossfingal
rossfingal is online now   Reply With Quote
Old 10-10-2011, 01:09 PM   #7
Mrsradell, I have no problem with using Silicone based caulks, since they stay more flexible, than acrylics. Only way you are going to notice the "slickness" of the caulk, is if you are right up on top of it, about maybe two feet away.
Sealing Replacement Windows Pittsville Windows and Doors 22 07-15-2011 04:04 PM
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 07:25 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 07:36 PM
