Sealing A Vapour Barrier In Garage - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-23-2008, 08:45 PM   #1
Sealing a vapour barrier in garage
I'm trying to figure out how I seal the vapour barrier along the ceiling in my garage. i used acousti seal along the bottom, but the ceiling is already drywalled and there is no wood visible to seal the barrier to. Any ideas anyone?
PatS is offline   Reply With Quote
Old 10-24-2008, 07:54 AM   #2
RippySkippy's Avatar
not sure I understand....if the ceiling is drywalled...why do you need to seal the vapor barrier? I assume you're looking at this from the attic side?
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 10-24-2008, 08:31 AM   #3
Designer
Rewards Points: 42
curious too
I live in a town home and i am a middle unit, I have a double car garage and it is full dry walled. however the Kitchen is right above the garage and in one spot there is a really cold spot.
I wanted to do the same thing.... and i still might, but a neighbor had the same problem, and was told it wasn't cause of the lack of insulation in there. It was because of the AC. The unit that goes outside(on my deck off the kitchen) needs a path to get the the basement or something and that was were the cold was getting in. just thought i might share that with you...
but i too would like to know the best way to insulate up in there, see as though its finished off now.
cdpage is offline   Reply With Quote
Old 10-24-2008, 11:22 AM   #4
concretemasonry's Avatar
Rewards Points: 2,608
The vapor barrier should be on the warm side of the insulation.
If you have sheetrock/drywall/softwall there may be something there and you should not be concerned with the seal of a "vapor barrier" (actually a vapor retarder) without being able to get to it.
If you create a second vapor barrier, you are creating a bigger problem.
concretemasonry is online now   Reply With Quote
Old 10-25-2008, 08:51 AM   #5
Engus's Avatar
I never heard of a 'vapor barrier' in regard to garage ceilings.
What purpose are you trying to achieve by applying a vapor barrier to a ceiling ?
There is such a thing as having a room or home (or garage for that matter) too tight.
Just like you and I, a building must be able to 'breathe' a little.
Too little vapor barrier and insulation, you lose too much heat and cooling ability.
Too tight and you run the risk of eventual water problems such as ruining your insulation, warping your drywall, etc.
The problem is finding the right balance.
Finding that right combination should be fairly easy to do these days. Simply visit a weatherization website, find out which 'zone' you live in, and insulate to that standard.
Engus is offline   Reply With Quote
basement insulation and vapour barrier coolnes Remodeling 11 02-01-2009 08:56 AM
vapour barrier in part of room? bluejay Building & Construction 1 05-07-2008 06:31 AM
Vapour Barrier Patching? mfleming Building & Construction 3 04-29-2008 12:00 PM
Carport to Garage: Fire barrier question Grommet Remodeling 2 03-28-2008 04:18 PM
Is this a double vapour barrier or not? KUIPORNG Remodeling 11 09-29-2006 10:13 AM
