Sealing Up Air Leaks Between - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-14-2008, 11:47 AM   #1
Rewards Points: 77
sealing up air leaks between
Sealing up gaps between the sill, foundation wall, and outside clapboard.
I am working on an old 1850's farm house and there are small gaps along the sidewalls where the sill, siding, and foundation all meet. I want to seal this up to prevent air and rodents from going through. I wanted to use spray foam, but figured the mice and rats could chew through it.
I also thought about sealing it up with concrete and then insulation on top so the mice and rats couldnt get in.
Any other ideas
troyce1 is offline   Reply With Quote
Old 10-15-2008, 08:11 AM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
It depends on the size of the gap. If its small then just caulk on the outside. Spray foam will also work but shouldn't be exposed to weather. From the inside you can just stuff pink fiberglass.
Brik is offline   Reply With Quote
Old 10-15-2008, 08:14 AM   #3
Send a message via ICQ to flameup
Look through amazon web site. They have more then enough such kind stuff.
flameup is offline   Reply With Quote
Challenge: Toilet Leaks through bolts but only when flushed! racerted Plumbing 53 10-21-2012 09:06 PM
Sealing up your Ducts jamiedolan HVAC 4 10-01-2008 12:16 AM
Icemaker leaks johnpius Appliances 1 03-17-2008 12:47 PM
How to monitor for leaks in a crawl space? twilightcall Plumbing 3 01-05-2008 11:38 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
