Sealing A Disused, Leaky Bulkhead - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-08-2014, 09:40 PM   #1
Sealing a disused, leaky bulkhead
Hi -
I live in MA and am attempting to make my unfinished basement usable. My home is a Cape built about 1950, and the previous owner put a deck over the original basement entrance. However, the basement is below grade and when it rains, water drips into the basement where the previous bulkhead door used to be (the new bulkhead and entrance are just fine). As far as I can tell, the old entrance is covered with some combination of wood and plastic sheets. I'll have to rip up some of the deck to get a good look at it.
My question is, how do I cover and/or seal this leaky old basement entrance? I'm thinking I may have to buy a bulkhead door that I'll never use just to seal up this hole.
Thanks!
bhekking is offline   Reply With Quote
Old 07-09-2014, 10:59 AM   #2
landfillwizard's Avatar
Rewards Points: 502
If you are not going to use the entrance any more have the old door sealed up with concrete block.
landfillwizard is offline   Reply With Quote
The Following User Says Thank You to landfillwizard For This Useful Post:
bhekking (07-13-2014)
Old 07-09-2014, 01:15 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Finished basement space will require and egress other than the stairs leading up to the house. This usually will mean an egress window.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 07-09-2014, 02:03 PM   #4
Rewards Points: 6,652
Re-read the OP post. They state that there is already a "New" Cellar door in place. They are trying to fix the problems from the hack job, that the previous owner did with the old Cellar door opening.
Tags
basement , bulkhead
Drywalling bulkhead and wall repair after basement reno Simon96Taco Drywall & Plaster 9 11-22-2013 11:38 PM
Drywalling bulkhead and wall repair after basement reno Simon96Taco Drywall & Plaster 0 11-21-2013 02:28 AM
Bulkhead Drainage Concern Enigma007x Landscaping & Lawn Care 2 09-04-2012 09:15 AM
Sealing a leaky old cement washtub Diydky Concrete, Stone & Masonry 4 04-23-2012 12:38 PM
Adding a roof over a bulkhead? 1parkpointer Building & Construction 1 12-08-2008 10:24 AM
