Sealing Cypress Wood And Beams - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-08-2009, 04:15 PM   #1
Sealing cypress wood and beams
I recently built an outdoor kitchen and entertaining area. I have lots of rough cut cypress beams and pecky wood cypress. I wish to seal the wood but not stain it. I want to keep the natural look of the wood but protect it from the elements. Very little of the wood gets direct sun. I live in Louisiana...very high humidity.
What product should I look at and also what application method should I use.
MDS58 is offline   Reply With Quote
Old 10-08-2009, 05:55 PM   #2
DIY staff
Rewards Points: 7,174
MDS--Some time in the last year Fine Home Building magazine had a great article on outdoor finishes.
It has a great read. Unexpected results.Check the library or on line.
I am sure the research time will pay off.---MIKE---
Old 10-08-2009, 07:18 PM   #3
I have read that the best clear finish for outdoor stuff is un-tinted outdoor paint. IIRC the recommendation was for the base for light colors. Evidently, it has better UV protection than almost anything and a long life. Now, I've never done this so recommend a web search for more specifics.
Mike in Arkansas is offline   Reply With Quote
Old 10-08-2009, 08:58 PM   #4
Registered User
Termite's Avatar
Spar urethane is an excellent finish for weather-exposed woods. It goes on like polyurethane and is available in satin and gloss. Of all the brands I've tried I prefer the Cabot brand at Lowes. I'd be sure the wood is good and dry before applying it, and ensure that the weatherman is promising about three days of sunshine after it is applied.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Faux Wood Beams JudyFaye Building & Construction 2 06-08-2012 04:05 PM
faux wood beams? zel Remodeling 11 07-07-2010 02:28 PM
beams wood or steel Bill Roden Building & Construction 2 09-07-2008 09:58 PM
How to remove faux wood ceiling beams? hfoster Remodeling 2 02-11-2008 09:11 PM
