Sealing Crack Sidewalk - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-10-2007, 07:40 PM   #1
sealing crack sidewalk
Do i need to seal the crack between my house and sidewalk? If so, what do I use to seal it?
cmb1128 is offline   Reply With Quote
Old 10-10-2007, 09:04 PM   #2
remodeling pro
It is probably not necessary to seal it, but it cannot hurt. Sealing it will help keep much water from getting down under the foundation. Use a polyurethane sealant made for concrete, they are available in the section with the bagged cement and morter mixes at the big boxes.
troubleseeker is offline   Reply With Quote
Old 10-13-2007, 04:22 PM   #3
Polyurethane is best bet. I used PL concrete & masonry sealant. Worked great consider the following buy a qt. of mineral spirits for clean up, you can buy as self leveling or not (flat or sloped) this stuff takes a while to cure (above 40 degress) so no traffic over it
Richard$ is offline   Reply With Quote
Sealing Brick Pavers sflamedic Painting 9 04-11-2011 10:17 PM
Concrete coming-cant find my crack maker justdon Building & Construction 8 09-16-2007 07:02 PM
crack in glass mirror rookie50 Building & Construction 3 12-04-2006 08:55 PM
Sidewalk Meets Concrete Truck Question craigNeasttx Building & Construction 5 03-25-2005 12:40 AM
sinking sidewalk Unregistered Building & Construction 2 11-22-2004 04:59 PM
