Sealant To Use With Hardiplank Siding - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-12-2010, 12:47 AM   #1
Question
Sealant to use with Hardiplank siding
We are getting ready to repaint the Hardiplank siding on our home in Oregon where it rains. We were told to use Sonolastic TX 1 sealant to seal the butt joins & around our windows on our Hardiplank siding.
Is this what you would use?
Thanks John
JPGO is offline   Reply With Quote
Old 07-12-2010, 04:17 PM   #2
Rewards Points: 5,336
Wasn't this caulked when it was first installed? Are there gaps now that should be sealed? I'm not familiar with the caulking mentioned, but whatever caulk you use, it should stay flexible and be paintable.
Ron
Old 07-12-2010, 06:15 PM   #3
Question
Oddly, They were not sealed when installed.
So my question is would it be okay to seal with Sonolastic TX 1?
Old 07-12-2010, 06:23 PM   #4
kwikfishron's Avatar
Rewards Points: 602
I’ve never seen or used TX 1 but from what I just read on the product it’s a polyurethane caulking. Vulkem and Quad are also polyurethane caulking’s and are both readily available off the shelf in any lumber, hardware, or big box store in Oregon. Both have served me just fine.
West of the Cascades, always Poly and never Silicone.
kwikfishron is online now   Reply With Quote
Old 07-12-2010, 07:03 PM   #5
Smile
Thank you for this information.
Old 07-12-2010, 07:12 PM   #6
"West of the Cascades, always Poly and never Silicone."
Why is that?
Ron
Old 07-13-2010, 01:21 AM   #7
i wonder if that hardi was flash installed. if flashing was used behind the plank it could explain why you have no caulk
racebum is offline   Reply With Quote
Old 07-13-2010, 05:19 AM   #8
Rewards Points: 602
Why is that?
Ron
Silicone just doesn't stick in wet environments.
A couple of years and you can grab that bead and easily pull it out. You can’t do that with poly.
Old 07-13-2010, 02:39 PM   #9
Registered User
Rewards Points: 5,516
Few years ago, Hardie said no caulking at butts around here..... now:
For best results use an Elastomeric Joint Sealant complying
with ASTM C920 GradeNS, Class 25 or higher or a Latex
Joint Sealant complying with ASTM C834. Caulking/Sealant
must be applied in accordance with the caulking/sealant
manufacturer’s written instructions or ASTM C1193.
From: http://www.jameshardie.com/pdf/insta...plank-hz10.pdf
Be safe, Gary
Old 07-13-2010, 07:06 PM   #10
Rewards Points: 156
Im a big fan of the Quad, it gets messy on the fingers and requires minieral spirits to clean as it is a poly, but paints over well and flexes well in our winter/summer seasons. I tried DAP acrylic on my first door project and by next year was peeling it off by hand.
creamaster is offline   Reply With Quote
Old 07-13-2010, 09:05 PM   #11
Question
Repaint my Hardiplank siding
What type of paint to repaint my Hardieplank siding.
I am told "not" to use oil base paint.
That leaves me with exterior Acrylic paint.
Is this the same as Latex paint?
Old 07-16-2010, 09:01 PM   #12
remodeling pro
I have never had trouble with silicone peeling off when it was applied under the proper conditions....the problem for me in this application is that silicone is not paintable. We use urethane to caulk all Hardi and Azek work, the stuff is tenacious. This is what they use to caulk vinyl replacement windows in place, so it is readily available at our local supplier, and I feel a higher quality product than the typical big box urethanes.
troubleseeker is offline   Reply With Quote
Old 07-16-2010, 09:08 PM   #13
remodeling pro
Generically speaking latex refers to a product that uses water instead of a solvent as the carrier. Acrylic is the additive that makes or breaks the quality of the paint. Use a quality brand like Sherwin Williams or Benjamin Moore, but if you decide on another brand, look for the words "100% acrylic" on the label.
Hardiplank siding project - quotes ATL2008 Remodeling 7 06-20-2008 12:10 PM
Hardiplank siding Clutchcargo Building & Construction 15 04-04-2008 05:17 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
