Screws Not Going In Door Frame With Cordless Drill - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-02-2010, 12:40 PM   #16
Rewards Points: 3,130
You say you made the pilot holes using "the long flat head screw." Could be part of your problem. Pilot holes are made with a drill bit.
Old 11-02-2010, 05:29 PM   #17
kwikfishron's Avatar
Rewards Points: 576
lcw, is that a metal door you drilled into? If so it's probably hollow and that’s why you can’t get any bight with your screw.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
oh'mike (11-02-2010)
Old 11-02-2010, 09:54 PM   #18
lcw
ok thanks md2lgyk.
Kwikfishron, I made the holes on the boarder. I haven't even attempted the door yet!
lcw is offline   Reply With Quote
Old 11-04-2010, 12:06 AM   #19
Wood Flooring & Carpentry
lawndart's Avatar
lawndart is offline   Reply With Quote
Need advice on cordless drill brand with a battery life of over 5 years?? stanlam Building & Construction 7 08-09-2010 11:31 AM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
Good Cordless Drill? MrBill_DIY Carpentry 18 06-22-2008 10:39 AM
Best cordless hammer drill for occasional use jaym3 Tools 6 11-11-2007 07:26 PM
