Screws Or Nails In Dbl Layer Of OSB - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-18-2012, 06:21 AM   #1
Screws or nails in dbl layer of OSB
Hello, I have a OSB plywood floor in my attic and its only 7/16" thick so Im adding another 7/16" thick layer on top to thicken it up and make it feel like Im not going to fall threw. Anyway, I already started screwing it together with coarse 1-1/4" drywall screws and some screws hold some don't they spin or strip out. My question is would fine thread drywall screws work better or would a certain kind of nail?
Thanks!
Chad
soggycashew is offline   Reply With Quote
Old 02-18-2012, 06:54 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,712
Ayuh,.... Just Don't tighten 'em so tight if their strippin' out...
Bondo is online now   Reply With Quote
Old 02-18-2012, 07:11 AM   #3
Rewards Points: 14,300
Pain in the butt but if you predrill the top piece it will pull the two pieces together instead trying to push the bottom piece away as it first grabs.
To keep it from stripping try using an adapter on your drill that's made for setting drywall screws.
Is this attic designed to hold all that extra weight? If not there's going to be a lot drywall damage down stairs over time.
mae-ling (02-18-2012)
Old 02-18-2012, 07:31 AM   #4
Experienced
Jackofall1's Avatar
Hope you slapping some construction adhesive between those sheets. It will sure help with the bonding.
Mark
Old 02-18-2012, 07:38 AM   #5
Crusty Old Dude
Big Stud's Avatar
I agree, use construction adhesive between layers. Also, longer screws ran through into joists will solve stripping problem.
All the best to you and yours, Tom
Big Stud is offline   Reply With Quote
Old 02-18-2012, 10:03 AM   #6
Rewards Points: 111
It will support the weight and thank you I will have to get my drywall gun out and some adhesive... Liquid nail
Thanks,
Chad
oxicottin is offline   Reply With Quote
Old 02-18-2012, 01:38 PM   #7
(the original)
Rewards Points: 756
Your 6ga, 1 1/4" drywall screws are too long, too skinny, and you're running them in too fast. Get some 8ga, 1" deck screws and install at low speed and all your problems will disappear. Yes on the adhesive.
ratherbefishin' is offline   Reply With Quote
Laying second layer of subfloor GeorgeV Flooring 6 09-15-2011 09:48 AM
Refinishing / Repairing Deck: Screws vs. Nails? superhandymom Building & Construction 1 05-10-2010 02:08 AM
Forgot to use galvanized nails... healeypd Building & Construction 8 05-12-2009 09:10 AM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 10:31 PM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 07:51 PM
