Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-12-2007, 11:56 AM   #1
Question
Screw in Track Lighting Bar Popping Out
Hi Everyone,
I installed a track light yesterday in the ceiling and not being really familiar with what I was doing and the instructions not being clear, I didn't notice there were toggle type "mollies" that needed to be used with the screws that attach the track bar to the ceiling. Well, one of the screws popped out and now there is a gap between the bar and the ceiling.
The rest of the fixture is secure and I really don't want to remove the entire thing so that I can put the toggle thing in the ceiling. Is there any way I can make the screw, or another one, grip in the ceiling so it will be flush? the hole is only so big so I think any type of anchor I use will be too small since the screw diameter is about the size of the hole in the track.
Any suggestions?
Thanks in advance!
Sue
SueC456 is offline   Reply With Quote
Old 03-12-2007, 12:19 PM   #2
Is this screwed into drywall, plaster and lath or other material?
redline is offline   Reply With Quote
Old 03-12-2007, 12:21 PM   #3
Sorry, I should have mentioned that. It is screwed into regular drywall.
Old 03-12-2007, 12:27 PM   #4
Choose one from below.
http://www.factsfacts.com/MyHomeRepa...lfasteners.htm
Old 03-12-2007, 12:35 PM   #5
I think any of those would require a bigger hole in the track bar. Would I have to drill one and is that safe to do? Thanks,
Old 03-13-2007, 08:24 AM   #6
Mots of these are installed before the unit is attached.
I think that you have two screws that hold that fixture.
Loosen the otehr screw slightly and move the fixture away from the screw hole that needs repair. Insert the new anchoring system then move the fixture back to the proper location. Insert screw thru the fixture and into the anchoring system.
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 02:54 AM
lighting guideline's - kitchen remodel dcd22 Electrical 3 08-01-2007 12:50 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Cable track lighting justtired Electrical 10 09-23-2006 01:53 AM
