Screw Nail Removal - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-16-2009, 01:24 PM   #1
Red face
Screw nail removal
My decking is attached with screw nails and I need to replace a large number of the boards. There are approx. 27 screws in each board and to use a cats paw and hammer is almost impossible. The boards are not next to each other so I can't remove one or two and then pry them up. Is there a tool available to speed up this process. Basically when I get the cats paw under the nail head I require a gorrilla to pull them out to point where I can get a bar underneath to fully extract them.
SC BOB is offline   Reply With Quote
Old 04-16-2009, 02:15 PM   #2
Registered User
Rewards Points: 4,924
I'd set a skill saw the correct depth, cut each side of each joist, an inch away. Smack the remainder 3-1/2" piece with a hammer towards the sky or in-line with the joist, whichever works. Use vise grips on the stubborn nails, with a spacer block. Be safe, GBAR
Old 04-16-2009, 10:18 PM   #3
Household Handyman
Rewards Points: 1,408
From experience- -another vote for GBAR's method.
Old 04-17-2009, 10:48 AM   #4
I don't know how to cut a 5/4 x 6 plank with a Skill saw as described without cutting the adjacent boards as well. Like I said I am replacing boards at random. I guess I could drill holes and use a saber saw but I rather set the deck on fire. Has anyone ever used a pneumatic nail removal tool?
Would you staple, nail or screw? Speedball Flooring 7 11-28-2008 12:21 PM
New deck, nail or just screw it! steve f Building & Construction 3 05-15-2008 09:17 AM
screw it or nail it? scatterbrain Building & Construction 5 06-25-2007 07:07 AM
nail removal on fascia big blue Building & Construction 4 10-07-2006 10:42 AM
Finishing nail removal bklauer Carpentry 6 09-05-2006 08:13 AM
