Saw Stand Feet - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-23-2016, 02:20 PM   #1
Rewards Points: 314
saw stand feet
the saw sits on the usual 4 metal leg stand.
it is about 1.2 inch too low.
the stand does not have those screw in feet on the bottom.
what are the bolts/ feet actually called?
thanks all
anon125 is offline   Reply With Quote
Old 01-23-2016, 02:50 PM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
do the legs have any holes in the bottoms? or can you drill a hole in the bottom of each leg?.if so you can just use a bolt with 2 nuts on each to give you whatever height you want, or if you want to make it portable get some caster wheels for it..
WhatRnsdownhill is offline   Reply With Quote
Old 01-23-2016, 04:42 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,060
Ayuh,... Put in on a couple of 2xs, 'n it'll be 1.5" taller,...
This seems to work,... Screw feet,...
Old 01-23-2016, 05:04 PM   #4
Rewards Points: 13,458
We have almost no info.
What saw?
Where are you tying to use it that it would make a difference?
Old 01-23-2016, 07:30 PM   #5
Rewards Points: 314
The bolts idea is maybe what I will try but I was hoping for better. Much larger head so the garage concrete floor does not get damaged.
I could instead put some wood between the saw stand and the table.
Still prefer the feet. There are holes in the legs for them.
Old 01-23-2016, 07:49 PM   #6
they sell feet with rubber or hard plastic on the bottom, take a look in the hardware isle at home depot..I believe they have a threaded bolt too..like these http://www.homedepot.com/p/Shepherd-...9909/100193891
Old 01-24-2016, 06:10 AM   #7
Bondo's Avatar
Ayuh,.... I guess ya didn't bother clickin' the link I posted,..??
Old 01-24-2016, 12:45 PM   #8
Rewards Points: 314
thanks for the links
yep that is what I am looking for in canada
Old 01-24-2016, 12:52 PM   #9
Rewards Points: 1,696
Myself I would buy some rubber wheel locking casters for it.
This depends on weather you only need the short height adjustment, or you can use a 4 to 6 inch lift.
As stated by a previous person , we need DETAILS!
ED
de-nagorg is online now   Reply With Quote
