Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-07-2005, 10:03 AM   #1
Sash out of square
Can anyone give me any advise as to how I can square up an old wooden casement window. During the summer this window is left hanging open, and I suppose the weight of the window has caused it to become racked, not I can't get the window to close securely. I checked the window frame and it is okay, but the sash is out of square.
Any advise????:confused:
Talman48 is offline   Reply With Quote
Old 10-07-2005, 07:15 PM   #2
Sash out of square
Pry, cut, kick, curse. Usually in that order. A picture might help.
K2eoj is offline   Reply With Quote
Old 10-14-2005, 07:48 PM   #3
johnh
Sash out of square
you probably will have to remove the sash in question. at that point you can either square it up or shave it down to fit. if you have an upper and lower sash i would check both. the weather tightness has been affected.
johnwhowe is offline   Reply With Quote
Addition "shell" cost per square foot - is this reasonable? ourzoo Building & Construction 21 12-20-2011 06:22 PM
Purpose of square black washer on outlet cover screws? darsunt Electrical 3 07-20-2007 11:27 PM
Ridge vent question dpreznik Roofing/Siding 7 04-13-2007 04:03 PM
Sash Window renovation DED Carpentry 1 05-25-2005 02:32 PM
