Sanding And Finishing A New Deck?? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-10-2008, 07:04 AM   #1
Rewards Points: 230
Sanding and Finishing a New Deck??
What's the best way to sand a new deck? Should I just use a belt sander or can I rent something bigger that would be more efficient? The deck is about 400 sq. ft. Also, what finishing products does everyone recommend for cedar? I think I want to keep the natural wood color and just us a clear sealer. Any suggestions? Thanks,
Kevin
Ler0y Jenkins is offline   Reply With Quote
Old 07-10-2008, 03:49 PM   #2
Licensed Contractor
For sanding the deck, I've rented a floor drum sander before when refinishing decks and it worked well, as long as the nails/screws were set below the surface, and you take care not to gouge the wood with the drum. Otherwise, I just use my 6" Festool random orbital sander.
As far as clear finishes for a deck, I don't recommend them. I've yet to see a clear finish that either protected the wood from the weather, or didn't fail after the first year. I'm an advocate of solid stains, as they provide the most protection for a deck. Just my opinion, fwiw.
Renovator,LLC is offline   Reply With Quote
Old 07-12-2008, 08:18 AM   #3
ccarlisle's Avatar
Orbital sanders are the way to go, forget drum sanders...Orbitals use a sheet of self-adhesive sandpaper that costs about $5 a sheet. I used three sheets of 36-grade coarse sandpaper to remove a solid stain that had deteriorated in about 3 seasons.
IMO solid stains, that lie on the surface, although they protect better from the suns rays, tend to crack and peel because of the physical expansion and contraction of the wood. Use a penetrating sealer to protect the subsurface from water and contains a UV filter. But leave the surface alone - unless you like painted wood of course...
ccarlisle is offline   Reply With Quote
Old 07-18-2008, 07:44 AM   #4
Rewards Points: 230
Thanks for the responses guys. I think I'll go with an orbital sander and a clear sealer. I like the look of the raw cedar contrasted with the white vinyl railing. I'll post pics when its all done.
Old 07-24-2008, 07:49 PM   #5
Message to leroy
Hopefully this isn't too late but be sure to use what they call fast and deep pentrating oil based stain on your cedar deck. With cedar if you use a clear stain/sealer the cedar will turn grey within 8-12 months. You need to use a pure oil based stain with at least a little bit of tint in it. Cedar decks need to be refinished every 2-3 years. Brands to use; Ready Seal, Baker's Grey Away, Total Wood Protection and Cabot's Australian Timber Oil although it can be really expensive.
npanco is offline   Reply With Quote
Reattaching baseboards? Joony Flooring 7 07-06-2008 08:11 AM
Finishing my garage walls sk72 Painting 1 05-14-2008 08:21 PM
Drywall Finishing kimmyb Building & Construction 5 01-26-2008 02:51 PM
tools for finishing drywall sedwick Building & Construction 8 04-21-2007 08:23 AM
Another Hardwood finishing question J187 Flooring 3 08-30-2006 09:12 PM
