Salvaging A Tile Job. HELP! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-25-2011, 10:06 PM   #1
Salvaging a tile Job. HELP!
So I tiled my kitchen floor yesterday. I back buttered every tile and layed it flat. I did not spread thinset on the backerboard like I now know I should. The tiles are not connected to each other with thinset like they should be. My question is; will the grout crack since the thinset is connected and can i squeeze thinset through the gaps to form a bond before grouting to salvage the job. (Will new thinset bond to the old?)
Any help will be greatly appreciated
Thanks Fred
f15david is offline   Reply With Quote
Old 05-26-2011, 02:38 AM   #2
Rewards Points: 282
say what
jcrack_corn is offline   Reply With Quote
Old 05-26-2011, 02:57 AM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Huh?
Tiles are connected to the backerboard with thinset. In between the tiles should be grout.
Old 05-26-2011, 04:11 AM   #4
Im sorry, let me be a little more specific. I did not create a mortar bed when tiling. I spread thinset ONLY on the back of the tile and layed it on the backerboard. Between tiles, you can see down to the backerboard. I am fearful that without a proper mortar bed the tiles will shift causing constant cracks in the grout. I hopeful I can fix this somehow
Thanks Fred
Old 05-26-2011, 05:14 AM   #5
DIY staff
Rewards Points: 7,174
Slow down a bit----How big are the tiles---what thinset did you use?
How wide are the grout lines?----What brand and type of grout are you planning to use?
Generally speaking--you should be O.K.---If----
you used a powdered modified thinset
You used the right sized trowel for the tile size
You pressed the tiles onto the backer so you have a good bond-------------
You will want to use a sanded grout---mixed from a powder--if the grout line is more than 1/8"
You will use more grout than the chart on the back of the bag---
Be sure to work the grout into the gap well--- and I think you will be successful.----Mike---
Old 05-26-2011, 05:39 AM   #6
Hey Mike. Thanks for take the time to respond. The tiles are 13x13 ceramic. We used bagged laticrete multipurpose pro thinset(and we used plenty, there is a good bond.) The grout lines are 1/4in. We are using laticrete sanded grout. A 1/4 notched trowel was used. Hope that sheds some light. Thanks Fred
Old 05-26-2011, 06:22 AM   #7
DIY staff
The trowel was a bit small for 13x13---easy enough to see if the coverage was adequate though.
Tap on the tiles with a screwdriver handle and listen to the sound---dull thump is good hollow ring is bad--
If the bond is good--go ahead and grout---the sanded grout can take that gap without issue.
Just make sure that you push that grout well into the void so you don't miss anything--
When grouting-- remember this---three steps to cleaning--
The first break---using sponges wrung almost dry---shape the grout lines and remove the majority of the excess grout--use a circular motion--you will only get a couple of tiles to a sponge-it will be ugly
at this point
Second break--This will clean most of the smear off the face of the tiles---Using sponges wrung almost dry--NO circular motion--straight pull parallel to the grout lines---set a sponge flat on the tile-
Press the sponge down gently and pull,while rolling the front of the sponge upward--
This is easiest to picture if you think of wiping up a glob of spilled jelly---you want to pick up the grout and expose a clean surface as you go.
You will only clean a couple of tiles to a sponge.
At this point the tile should look pretty good--lots of haze and a few streaks dragged from the grout lines.
Have a cup of coffee---now for the final wipe---Lots of wringing here--Same press--pull and roll motion---one sponge = one tile.
The final wipe should leave you with clean shiny tiles---If not,you're not done--do it again.
Tomorrow is to late---I don't want to see you back here with a ,"How do I get grout off the face of the tile?" post.
Have fun---Mike---
The Following 3 Users Say Thank You to oh'mike For This Useful Post:
Blondesense (05-26-2011), DrHicks (05-26-2011), jomama45 (05-27-2011)
Old 05-26-2011, 07:42 AM   #8
Rewards Points: 5,336
To add to Mike's grout summary, I like to strike the grout lines with a dowel before cleaning the surface the second time. By doing this, you compress the grout into the surface and create a uniform grout line through out.
For a 1/4" grout line, I'd use either a 1/2" or 5/8" dowel. If you pick one that's too thin, you remove the grout. The wider the dowel the shallower the grout depression.
Ron
The Following 3 Users Say Thank You to Ron6519 For This Useful Post:
Old 05-26-2011, 09:40 AM   #9
Stuck in the 70's
As long as they were set firmly I don't believe there is a problem. At least I hope not.
I tiled my shower last fall. I'm no expert, but I basically did the same thing you did. I backbuttered 12" tiles using a 1/4 trowel and a modified thinset. Then used a sanded grout. All's well so far.
Mike is right. Don't rush the cleaning, but don't go to bed until the tiles are as clean as you're ever going to want them. That haze won't come off the next day. If you have one, a microfiber cleaning towel is awesome for the final wipe down.
One last thing, do your clean up outside. Don't dump the excess grout down the toilet or drain.
Old 05-26-2011, 09:47 AM   #10
A Little Of Everything
Rewards Points: 1,364
Ron
Are you talking about a regular wood dowel?
DrHicks is offline   Reply With Quote
Old 05-26-2011, 09:48 AM   #11
By the way, kudos to Mike & Ron. Thanks for some excellent advice!
The Following User Says Thank You to DrHicks For This Useful Post:
oh'mike (05-26-2011)
Old 05-26-2011, 09:52 AM   #12
DIY staff
[quote=Blondesense;655283]
Excellent suggestion on those micro fiber cloths---They are great.
Old 05-26-2011, 09:59 AM   #13
Doesn't that depend partly on the tile? We helped a friend of ours move into a newly remodeled house she bought. It had the gloss white 4x4 tiles in the bathroom in the tub/shower. All hazy, but it wiped off just fine.
Old 05-26-2011, 10:11 AM   #14
Stuck in the 70's
True. I understand a high gloss glazed tile like subway tile will most likely clean up OK. But why risk it.
The original post said this was a floor so I assumed this wasn't a high gloss tile.
Old 05-26-2011, 10:45 AM   #15
Yes, a regular wood dowel.
Ron
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
