Salvaging The Floors Under Glued Down Hardwoods - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 02:03 PM   #1
salvaging the floors under glued down hardwoods
The idoit who owned our house before us glued hardwoods directly onto beautiful pine wood floors in the kitchen and dining area (and covered the rest of the pine with carpet throughout the rest of the house). We were very pleased and shocked when we took up the carpet and saw the floors and have since sanded and stained them and they are beautiful! But as we are ripping up the glued down hardwoods in the kitchen and dining area, it is destroying the floors underneath.
Is there any way to remove the glued down hardwoods and salvage the floors underneath?
salvaging the floors under glued down hardwoods-photo-16.jpg   salvaging the floors under glued down hardwoods-photo-17.jpg
christymichael is offline   Reply With Quote
Old 03-06-2011, 02:10 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Heat?
XXX
Old 03-06-2011, 02:53 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,710
Ayuh,... Keep doin' the same thing,...
Rip it up, sand it, 'n finish it....
I caulked mine with black putty,...
The more destressed areas, Still look Great....
Old 03-06-2011, 08:40 PM   #4
as were pulling up the glued down stuff, its breaking the floors underneath, accidentally tore up almost a half inch in one part! is there a way to prevent that from happening? are those the spots you filled with black putty?? Thanks so much for the reply! your floors are GORGEOUS!!!
Old 03-07-2011, 06:50 AM   #5
Bondo's Avatar
Ayuh,... That's correct...
Old 03-07-2011, 07:31 AM   #6
Rewards Points: 5,336
Taking it up the way you're doing it will trash the floor underneath.
Take a circular saw and set the blade 1/8" shallower then the top floor. Make a series of cuts in the floor and pry up small pieces at a time. Always put pressure on the top floor when prying or you'll damage the pine under it. The floor you're removing looks to be a multi-ply material. If you set the blade correctly, the last ply will still be stuck to the flooring. Use a sander with a 60 grit paper to sand through the last ply
The tricky part will be the adhesive. You can try to sand through it, but it might clog up the paper too quickly. Or you can try to get the bulk of it off with solvent or a heat gun. Both of these are hazzardous and should be done with extreme care. Have fire extinguishers at the ready.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
christymichael (03-07-2011)
Removing Glued Down Hardwoods, Save floors under christymichael Introductions 2 03-11-2011 07:18 PM
Rejuvinate hardwoods? Thomolli Flooring 1 08-18-2010 09:24 AM
Resurfacing Wood floors roxksears Building & Construction 2 10-23-2009 08:50 AM
Hardwood floors glued over Redguard. Help!!!! clopez0903 Flooring 4 07-16-2009 07:44 PM
glued down carpet...can I cheat? Dusty Flooring 3 10-10-2006 05:18 PM
