Safety Violation? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-24-2014, 04:56 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 816
Safety Violation?
Can you spot the safety violation in this photo?:
in case you need help....neither one is wearing safety goggles
ddawg16 is online now   Reply With Quote
Old 03-24-2014, 05:02 PM   #2
Rewards Points: 626
Nope looks all ligit to me, carry on!
Nailbags is offline   Reply With Quote
The Following 3 Users Say Thank You to Nailbags For This Useful Post:
curtd (03-30-2014), gregzoll (03-24-2014), SHR Plumber (03-25-2014)
Old 03-24-2014, 05:10 PM   #3
Rewards Points: 12,812
No knee pads, One's not wearing hearing protection.
Is that it?
Old 03-24-2014, 07:31 PM   #4
Rewards Points: 6,652
They are both missing duct tape on their footwear.
Old 03-24-2014, 09:04 PM   #5
Rewards Points: 125
The guy kneeling is not wearing safety gloves.
ptarmigan61 is offline   Reply With Quote
Old 03-24-2014, 09:31 PM   #6
Rewards Points: 140
Fix'n it is offline   Reply With Quote
Old 03-24-2014, 11:34 PM   #7
Rewards Points: 142
Gives a new meaning to plumbers crack. Nice one dawg!!
jmon is offline   Reply With Quote
Old 03-25-2014, 11:01 AM   #8
Rewards Points: 147
I've got it. The Bozo is lifting up the blade guard. Clearly an OSHA violation.
Rango is offline   Reply With Quote
Old 03-25-2014, 11:10 AM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 816
It is?
Old 03-25-2014, 11:22 AM   #10
Rewards Points: 147
It is?
I would assume so since it's required to be in place.
1910.243(a)(1)(i)
All portable, power-driven circular saws having a blade diameter greater than 2 in. shall be equipped with guards above and below the base plate or shoe. The upper guard shall cover the saw to the depth of the teeth, except for the minimum arc required to permit the base to be tilted for bevel cuts. The lower guard shall cover the saw to the depth of the teeth, except for the minimum arc required to allow proper retraction and contact with the work. When the tool is withdrawn from the work, the lower guard shall automatically and instantly return to covering position.
Old 03-25-2014, 11:52 AM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 816
I know the guard is required...but what says you can't lift it when you start your cut?
The Following User Says Thank You to ddawg16 For This Useful Post:
gregzoll (03-25-2014)
Old 03-25-2014, 12:22 PM   #12
Rewards Points: 147
I said I assume so since it's required. I don't imagine OSHA is going to require a safety feature that's optional. I'll let someone else test the theory.
Old 03-25-2014, 01:59 PM   #13
Rewards Points: 5,974
Some cuts are impossible with out lifting the guard. It's allowed.
Old 03-25-2014, 02:16 PM   #14
JOATMON
ddawg16's Avatar
Rewards Points: 816
BTW guys.....this is really sad......
I post a pic for humorous value....and we go off on a tangent talking about real safety issues.....
So sad...
Old 03-25-2014, 02:38 PM   #15
Rewards Points: 147
So sad...
I thought you were the one that went off on the tangent?
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
Trap and washing machine safety drain pan wildbilly Plumbing 18 03-05-2013 08:08 PM
Are these good respirators and safety masks? darsunt Tools 3 02-24-2013 08:34 PM
Garage Door Opener Safety Reversal NJPhily Windows and Doors 12 05-21-2012 09:50 PM
Homeowners And Safety. Roofmaster417 Roofing/Siding 0 05-04-2011 12:41 AM
