Rusting Patio Support Beams - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-05-2008, 05:16 AM   #1
Rusting patio support beams
Both of my patio support beams are rusting at the bottom. I believe they are sunk in the concrete beam across the top of the patio. I have no clue how to fix this.
Lisa9753 is offline   Reply With Quote
Old 01-05-2008, 09:31 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 602
Ayuh,....
Scratch,+ sand the beams as well as you Can,+ Paint them........
Rustolium would be a Good Choice,.....
I'd use the Rust-Oxide Primer,+ a top coat in the color of your choice......
Bondo is online now   Reply With Quote
Old 01-05-2008, 09:45 AM   #3
Rewards Points: 334
A picture would help -
Rust - as in holes that the support is weak and needs repair/replacement, or a little surface rust that can be repaired as Bondo stated ?
tribe_fan is online now   Reply With Quote
Old 01-05-2008, 12:02 PM   #4
I cant figure out how to attach a picture. I keep getting failures. The bottom of one of the beams has a finger sized hole in it and there is bubbly rust around the bottom of both of the beams. Steel doesn't do good in the south florida area. Any clue what to do to fix this? It is damaged beyond what rustoleum can do. Thanks for any help you can give me.
Old 01-05-2008, 12:35 PM   #5
Rewards Points: 334
Try photobucket or webshots and post a link to it.
It really sounds like they need to be cut out and replaced, using a different method/material to attach to the bottom. I'd be VERY careful in the mean time.
slumped patio fix ?? houser Building & Construction 5 03-18-2010 07:25 AM
Replacing support beams Annimal76 Remodeling 1 09-10-2007 11:12 AM
where to get support beams elementx440 Building & Construction 5 03-21-2007 06:19 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
help with support beams on porch falcon802 Carpentry 3 06-24-2006 11:00 AM
