Rust Removal From Cast Iron Tub - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-07-2011, 03:00 PM   #1
Journeyman Wireman
Rewards Points: 150
Rust removal from cast iron tub
My daughter had a metal teapot in the bath with her. It left a rust ring on my cast iron tub. How can I remove it without damaging the finish?
Tub is 12 years old. Rust has been there for a while. Have not tried any abrasives to remove it.
Jupe Blue is offline   Reply With Quote
Old 05-07-2011, 09:26 PM   #2
Rewards Points: 5,336
Try wetting the surface, applying Zud and rubbing with a nylon scrub pad.
Ron
Old 05-08-2011, 06:54 AM   #3
CLR, Calcium/Lime/Rust remover, any home, hardware store. Do not scrub that surface with anything abrasive, you will dull the finish.
Old 05-08-2011, 08:40 AM   #4
Rewards Points: 472
Navel jelley will do it. Or go to a boat place and ask them for a stain remover. I can't remember the name it is blue in color that will work also.
del schisler is online now   Reply With Quote
Old 05-08-2011, 09:13 AM   #5
Rewards Points: 558
You can also use a clean soft rag which was dipped into turpentine and slightly rinsed out. Be sure to wear gloves and eye protection when doing this and make sure the area is well ventilated.Then sprinkle ordinary salt onto the the rag that is wet with turpentine like the corner then scrub the brown rust stain until the stain has disappeared. Reapply turpentine and salt if necessary. When the stain is gone, rinse the cast iron bathtub with plain water and dry tub with a dry rag and you’re done.
epson is offline   Reply With Quote
removing rust from a vintage painted cast iron doorstop Margo Painting 6 03-08-2011 03:22 PM
Remove Rust from Cast Iron Bed Rails cpalmer67 General DIY Discussions 8 07-24-2009 02:25 PM
cast iron tub removal help frogger Building & Construction 37 12-01-2008 02:31 PM
remove rust cast iron tub workingirl General DIY Discussions 13 08-23-2008 02:41 PM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 08:20 PM
