Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-06-2011, 11:00 PM   #1
Rust Question
I set a j bolt anchor into concrete this afternoon. I mistakenly set it an 1/8" too high for the simpson connectors. I will probably need to grind off 1/8" from the top of the bolt to make them fit. Will this cause an appreciable rust problem where I take off the HDG finish.
ovahimba is offline   Reply With Quote
Old 11-07-2011, 12:04 AM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Rust Question
Anything left out in the environment will rust or corrode over time. There is just no way around it.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 11-07-2011, 12:08 AM   #3
JOATMON
ddawg16's Avatar
Rust Question
What kinds of simpson connector are you using where the bolt height is an issue?
As for rust....don't worry about it.....after awhile it acts like LocTight.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 11-07-2011, 12:24 AM   #4
Rust Question
Thanks for the replies. I'm using the ABU44 standoff post base. The separate standoff platform won't sit down all the way because the bolts protrude a bit too much from the surface of the concrete.
Old 11-07-2011, 01:43 AM   #5
JOATMON
ddawg16's Avatar
Rust Question
Oh...ok......yea.....just hack off what you need.
My
and
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
