Running A Natural Gas Line - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-11-2004, 09:36 AM   #1
Running a natural gas line
What are the different products to use to run a gas line to my grill. The grill is on a raised deck. It is about 40 feet from the shut off to the grill.
Roger is offline   Reply With Quote
Old 02-27-2009, 01:53 AM   #2
if allowable in your area, plastic is best and used now in California almost always. green polyvinyl coated pipe is next best, and much easier if you have not ever welded the plastic unions. Just be sure to tape the joints w/10mil tape as tight as you can get it. Many areas you are required to be certified to use the plastic.
allencd@cox.net is offline   Reply With Quote
Old 02-27-2009, 08:42 AM   #3
Registered User
Termite's Avatar
this is a five year old thread.
Condensate Line schott HVAC 17 06-02-2008 04:16 PM
Demo of Natural Gas Line millipede Safety 3 11-13-2006 02:13 PM
running the sump pump to the sewer line Jack Hass Plumbing 9 11-02-2006 10:36 AM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 08:51 AM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 09:19 PM
