Rubber Baseboards? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-05-2008, 05:23 PM   #1
Rubber Baseboards?
I was wondering if anyone knows where I can get some cheap baseboards that are very easy to put on. I've seen them at my office building they look like they're a rubber material and they're glued on or stuck on with some type of adhesive, they don't look like they're expensive. I just need something I can put up in my little kitchen. If anyone knows what I'm talking about and knows where I can get them please let me know.
Thanks,
Dank
dankreboot is offline   Reply With Quote
Old 07-05-2008, 05:48 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
They are not expensive
You should be able to find them at your local home center or contractor supply
Larger hardware stores may also have them, if they carry trim and such
They come in a roll, so they may not look like what you think if you passed them in the aisle
They must be laid out flat for a few days (or a week is better) at room temp before you use them
They may also have smaller pieces that are flat
If you have a small room and don't mind more seams, you might see if they have the pieces
slickshift is offline   Reply With Quote
Old 07-05-2008, 09:39 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
cove base molding
wall base molding
vinyl base molding
any of the above.
available in many colors. Rolls or flat stock from 4' to 20' pieces. generally 4" but also available in 6".
before you actually install this, look around and learn how to install it properly. It is not rocket science but there are tricks to making it look good. Corners are usually the hardest thing for most people.
Reattaching baseboards? Joony Flooring 7 07-06-2008 08:11 AM
Help with repairing a flat rubber garage roof Toasty Roofing/Siding 2 07-01-2008 08:43 AM
Rubber roof prices tgf40 Roofing/Siding 4 05-27-2008 01:02 PM
Click lock floors under baseboards ? bcarwell Flooring 4 03-30-2008 11:03 PM
Portico Rubber Roof handy man88 Roofing/Siding 7 12-03-2007 02:44 AM
