Router Dust Control - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-20-2010, 04:18 PM   #1
Router dust control
I have a Porter-Cable 690lr router for which I am trying to find a dust collector fitting. I'm planning on making a large number of cuts (I don't have or have access to a TS) to build a cubby hole type storage cabinet with adjustable verticle dividers. Of course, the sides will have cuts to accommodate the top, bottom, and horizontal shelves. The horizontal shelves will have grooves to accept the movable vertical dividers. I will be using MDF and there will be lots of dust that I prefer not to breath even though I will be wearing a high quality mask there will still dust all over the work area.
I will appreciate your hints and leads. I have done considerable research only to find that PC has discontinued its dust collector attachment, but I think that it only fit on the bottom which would not be useful in any case since when one is cutting groves in a surface one must capture the dust from the top.
Thank you for help and I look forward to you replies.
Novice Jack
novice Jack is offline   Reply With Quote
Old 09-20-2010, 04:58 PM   #2
Rewards Points: 262
They sell a tool adapter for Shop-Vacs at the home improvement stores that has 3 sizes.
Jim F is online now   Reply With Quote
Old 09-21-2010, 02:22 AM   #3
Thank you
I'll look into that right away. I hope to get into my project tomorrow, Tuesday.
Novice Jack
Old 09-21-2010, 12:27 PM   #4
Jim, I just got back from Home Depot and visiting HD and Lowe's web sites and no luck anywhere. Can you be more specific about where I should look. I have also tried Rockler and the Porter-Cable customer support people.
Old 09-21-2010, 01:16 PM   #5
Rewards Points: 22
Jim's right. I have seen them in most chain stores, as well as my local lumber yards, etc. I'm not going to look at Rockler's, because you need to decide what you want, but just to be sure that I wasn't loosing it, I just looked at the PC site, and they do have at least a 24" one under accessories.
Old 09-21-2010, 07:46 PM   #6
Rewards Points: 262
This is what I was talking about.
http://www.lowes.com/pd_37045-20097-...uantity_sold|1
They also have these if you have the small hose version Shop Vac.
http://www.lowes.com/pd_98553-20097-...uantity_sold|1
Old 09-22-2010, 08:05 AM   #7
47_47's Avatar
Rewards Points: 44
Rockler sells a universal dust port for edge routing.
http://www.rockler.com/product.cfm?p...%20dust%20port
I don't believe there is an aftermarket port for this router to do off-edge routing. Festool makes a router with a built in dust collection port.
http://www.mcfeelys.com/product/574267.
At this list price, you could get a decent table saw.
47_47 is offline   Reply With Quote
Old 09-26-2010, 11:45 PM   #8
Thanks folks, after lots of research I too have come to the conclusion that there is no such thing as the item that I am seeking, an attachment that fits on the router to collect the dust as it is being generated. The attachment that I have for the router table works great, but for this job I only needed four table cuts and over 50 free hand cuts using a clamp/guide. It appears that one must purchase a router that already has the dust collection feature build-in or one is out-of-luck.
You're right about the cost of that particular router; for that kind of money I could have a table saw. Now I just need a little more space in my garage, but don't we all.
I have completed my little project and am not painting it. Making it out of MDF is convenient, but it weights a ton.
You have all been good buds to try to help and I appreciate it.
Novice Jack
wiring blower for dust control orsillac Electrical 1 07-04-2010 10:51 AM
Ceiling Fan Speed Control czars HVAC 0 01-14-2010 09:06 PM
How a saw stand's dust box work Klawman Carpentry 3 12-07-2009 04:19 AM
Use stone dust under bricks to form a border around flower bed Curious123 General DIY Discussions 4 08-23-2009 04:41 PM
Control Dust in Basement Remodel Siamese Remodeling 4 03-19-2008 03:47 PM
