Router Bit Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-11-2017, 11:03 AM   #1
Rewards Points: 12
Router bit question
I am using a round over bit on some pine and the bearing has started leaving a mark on the wood. Can this be oiled somehow or do I need to replace the bit? I notice an allen head on top of the bearing. I am using very little pressure as I go around.
red_bike is offline   Reply With Quote
Old 01-11-2017, 11:18 AM   #2
Rewards Points: 3,846
Re: Router bit question
Pine is a very soft wood and your probably putting excess pressure on the tool to keep it against the wood, try a little less pressure.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
red_bike (01-11-2017)
Old 01-11-2017, 11:20 AM   #3
Civil Engineer
Rewards Points: 4,956
Sometimes the bearing sticks, in which case it can leave a mark in soft wood. You can try cleaning the bearing and shaft, no oil should be needed. If you cannot get the bearing to run free, you need to either replace the bearing or the whole bit.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Old 01-11-2017, 11:29 AM   #4
Rewards Points: 12
I am using very little pressure so I think the bearing is sticking. It seems to roll ok by hand. It just started doing it. How would I clean the bearing?
Old 01-11-2017, 11:49 AM   #5
World's Tallest Midget
Mort's Avatar
Rewards Points: 694
Blow it out with compressed air.
I hate signatures.
Mort is online now   Reply With Quote
The Following User Says Thank You to Mort For This Useful Post:
Old 01-11-2017, 03:17 PM   #6
Rewards Points: 12
Here is what I found. If I push on the bit with the router off, the bit would move a little. So I removed the bit and the nut and found that the Collet (I think that is what it is called) is broken into pieces. Glad the bit did not go flying out while it was on.
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 08:11 PM
quick question on closet flanges corman Plumbing 3 11-18-2012 03:18 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
