Rounded Bullnose Seam Popping - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-03-2009, 05:05 PM   #1
Rounded bullnose seam popping
The seams are popping out along our metal rounded bullnose along a niche and in a closet. Not sure if it was originally tacked down or what. Doesn't seem to be based on the lenghth of seperation.
Any suggestions on repair and tecturing back the area? I'm a novice but good at following directions.
Thank you!
ddavis2560 is offline   Reply With Quote
Old 01-03-2009, 07:00 PM   #2
Not quite sure what I am looking at, but it seems to be a taped joint that was not taped or nailed down, as you supect.
Old 05-15-2016, 01:33 AM   #3
Rewards Points: 4
Re: Rounded bullnose seam popping
Ya, whoever installed that bullnose, did not do a sufficient job. I would rip it out, apply a new layer of joint compound and new bullnose tape and then at least two more layers of compound and feather it into the existing surrounding layers. You'll need to texture and paint again of course.
Redrockrunner is offline   Reply With Quote
Old 05-31-2016, 04:22 PM   #4
Rewards Points: 42
Looks like a niche that is used as a shelf for kids toys. That being said you may be better off lining the bottom of the niche with wood and facing the bottom front of it with trim so it looks like a nice little wooden shelf that will hold up to the kids.
Otherwise I'd agree with Redrockrunner's advice.
Joeycarnuba is offline   Reply With Quote
Baseboards around Rounded Corners hgiljr Carpentry 13 09-10-2012 07:08 PM
bullnose won't hide subfloor? sonofthetonsured Flooring 8 06-10-2008 12:28 PM
Loud Popping Noises - when HVAC is Turned On. San Fran HVAC 2 01-04-2008 10:44 PM
I'm going to end up with a seam of greenboard meeting plaster, how should I finish? J187 Building & Construction 2 06-06-2006 08:53 AM
