Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-02-2006, 02:25 PM   #1
rotten bathroom floor
What is the easiest way to go about removing the rotten part and replacing with new
jwjr40 is offline   Reply With Quote
Old 09-03-2006, 09:05 AM   #2
Master Craftsman
Big Dave's Avatar
There is never an easy way to do anything. I would start by taking up the floor covering and then removing the rotted part back to good material at the top of a floor joist. You can then replace the rotted part with new material of the same thickness and install new floor covering.
Dave.
Do one thing at a time, do it well, then move on.
Big Dave is offline   Reply With Quote
Old 09-03-2006, 01:44 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Ohhh....yuck....
Rotten Bathroom floor. Let me guess...leaking tub/shower?
Chances are that the joists may be bad in some areas too. When you open the floor up check for pest damage because of the moisture. If the joists are rotted too, you may have to sister them up.
- Build Well -
Rotten bathroom subfloor tallycat77 Flooring 14 02-08-2013 10:59 AM
Leaking bathroom floor patatura Flooring 6 12-06-2008 07:30 PM
bathroom floor looks bad!! drb Flooring 13 03-10-2007 09:19 PM
old uneven bathroom floor toubob Flooring 4 02-15-2007 02:39 PM
bathroom floor tile job advice needed dbrew Flooring 14 01-23-2007 08:03 PM
