Rotted Floor Beams - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-22-2008, 09:17 PM   #1
rotted floor beams
i found that i have some floor beams with rotted ends i was wounderin if any one could tell me the propper way to sister them.
any advice would be great
T capone is offline   Reply With Quote
Old 06-22-2008, 09:28 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Put a spreader beam across several of them and jack the house a bit. Add the new, including bands, and sill plate if necessary.
NOW! Why are they rotted? Unflashed deck or windows?
http://www.rooferscoffeeshop.com/sho...&file=7449&s=0
tinner666 is offline   Reply With Quote
Old 06-22-2008, 09:43 PM   #3
just bought house had a bad roof
Old 06-23-2008, 05:24 AM   #4
Pro Slate Roofer
tinner666's Avatar
MY first answer was simplified, but the truth is, I've never seen the joist ends bad without soft saggy plates too. Get 3-4 house jacks and lift at 8 joists if you need to replace 4-6, etc. If necessary, unbolt band and cut it out. Also, if necessary, add more bolts. Use PT wood for band and sill, and Hot dipped nails, and hot-dipped bolts.
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Replace rotted 2x4's in cement patio KennS Building & Construction 3 06-18-2008 11:41 PM
repairing rotted sill dwlodyka Building & Construction 4 02-27-2008 07:38 AM
Rotted floor boards. How do I fix THIS??? gshock Building & Construction 4 08-14-2007 06:59 PM
Rotted Subfloor under concrete amy Flooring 1 10-27-2005 09:36 PM
