Rotted Columns - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-29-2012, 05:13 PM   #1
Question
rotted columns
Porch columns rotting on bottom of columns, near base.
also don't know if the columns are load bearing or not.
Any solutions to problem other than replacement?
Thanks!
Joe
josephb is offline   Reply With Quote
Old 06-29-2012, 06:13 PM   #2
Too Short? Cut it Again!
Hi Joe! Take a look at the wood restoration products from Abatron. If it is just rot at the bottom and the integrity of the columns is otherwise alright the products should work out great for you. If something has eaten, not rotted the base of the columns you should probably think about replacing them. Abatron has amazing customer support by the way. I found the company when I was restoring sailboats and used their products all the time in restoring antique homes. Be warned the prices are not for the faint of heart but the products are well worth it and certainly cheaper than column replacement if it fits your situation.
http://www.abatron.com/buildingandre....html?vmcchk=1
The Following User Says Thank You to user1007 For This Useful Post:
josephb (07-03-2012)
Porch column base rotted RickO General DIY Discussions 17 10-25-2011 09:43 PM
Rotten Rotted Header! jlatulippe Building & Construction 1 10-06-2010 09:28 AM
Replacing Porch Columns mcwolfe6 Building & Construction 8 05-12-2010 07:51 PM
Do I need to replace my Lally columns? charbroiled Building & Construction 5 09-24-2009 09:29 AM
columns / roof oar Building & Construction 1 12-05-2006 11:16 AM
