Rot At Base Of Exterior Stucco Wall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-26-2010, 11:06 PM   #1
Rot at Base of Exterior Stucco Wall
On one side of our house we have a grassy area that rests directly up against the house wall, which is made of stucco. About 5 inches up from the ground there is a lip and a metal piece below the lip. We have noticed in this area that the stucco is beginning to fall off and the metal appears to be rotted through. The sprinklers hit that area of the grass, but we've never seen a drainage issue in that area and water does not pool up against that area of the house.
So I'm unsure if this is normal, or what the issue is, and how to solve it...any help would be greatly appreciated!
mdudlest is offline   Reply With Quote
Old 09-26-2010, 11:16 PM   #2
Enough is Enough
H. A. S.'s Avatar
Have any pics??
H. A. S. is offline   Reply With Quote
Old 09-27-2010, 05:29 AM   #3
DIY staff
Rewards Points: 7,174
Real stucco or Dryvit?
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
BigJim (09-27-2010), Thurman (09-27-2010)
Old 09-28-2010, 09:13 AM   #4
Rewards Points: 1,014
You may consider looking for a contractor. These types of problems are usually not minor. You are probably looking at some degree of stuco tear off, sill plate replacement, stud and sheathing repair
Anti-wingnut is offline   Reply With Quote
Old 09-28-2010, 05:51 PM   #5
Registered User
Rewards Points: 526
It sounds like part of the weep screed metal along the bottom needs replacing: http://books.google.com/books?id=mFT...age&q=&f=false
At least you can get an idea if it's a repair you are capable of: cruise around-- http://books.google.com/books?id=0dz...age&q=&f=false
Gary
In The Process Of Building My Very First Small Retaining Wall ricksample Landscaping & Lawn Care 3 03-19-2010 09:19 PM
Considerations when pouring concrete against a stucco wall? clint_nichols Building & Construction 9 09-24-2009 05:28 AM
removing/replacing base molding on brittle plaster wall alt Remodeling 3 09-08-2009 09:28 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
