Roof Frame/Truss Weak Spot - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-04-2011, 08:32 PM   #1
Rewards Points: 236
Hi,
I am planning to install TV antenna in my attic.
In doing so, I started to inspect my attic which have one of the heat-pump unit in it. I noticed the roof frame/truss configuration and started to plan where I should mount the antenna and feed the coax cable.
In doing so, I start to ponder if I crawl around these roof and stepping on the frame/truss, would there be the roof frame/truss weak spot where I should NOT step on? I don't want to break anything.
Thank you!
Nick
Attached is the roof frame/truss of my house.
325_man is offline   Reply With Quote
Old 12-04-2011, 08:37 PM   #2
Framing Contractor
Rewards Points: 118
Gemerally, walking on any part of the bottom chord should be ok. If you can bring up some strips of plywood, you could span over a few trusses and make things even nicer. Usually, the weak spot is when you misstep and land on the ceiling material.
sixeightten is offline   Reply With Quote
Old 12-04-2011, 08:38 PM   #3
Rewards Points: 13,446
There should not be any "weak" spots. For your own safety it would be a good idea to lay a piece of plywood or OSB down to stand on. If you happen to slip off the truss cord you'll go through the sheetrock.
Old 12-04-2011, 09:12 PM   #4
Rewards Points: 236
I just want to mention that while I stated the type of roof truss, I am not sure if it is the exact type. My house was built in 2004.
Do you know if any roof truss type do not have any weak point?
very difficult house to vent roof help please marlowe Roofing/Siding 7 09-10-2011 11:57 AM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 05:12 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 10:02 PM
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 06:11 PM
