Robertson Tip Stuck In Screw - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-04-2011, 04:28 PM   #1
Robertson tip stuck in screw
I was using a Robertson driver (manual) and the tip broke off in the screw. Not only that but I need to remove the screw. How can I remove the screw? I know there are screw removal tools but I'm guessing it wont be able to go through the tip of the Robertson that is stuck in the screw as that is a harder metal. Thanks.
djgrant is offline   Reply With Quote
Old 07-04-2011, 04:34 PM   #2
DIY staff
Rewards Points: 7,174
That's not good---try drilling along side the broken tip perhaps you can pry the tip out before the head is unusable.
Old 07-04-2011, 11:33 PM   #3
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
How far in is the screw? Can you get a set of vise grips on it? Can you grind the sides of the screw head flat to get a better grip?
WirelessG is offline   Reply With Quote
Old 07-04-2011, 11:54 PM   #4
I'll check and give it a go, thanks.
Old 07-05-2011, 05:18 PM   #5
Household Handyman
Rewards Points: 1,408
Remember that the Robertson tip is stuck in the screw head in the diredtion in which you were turning it--sounds like you were attempting to loosen the screw. This means the tip is stuck in the CCW postition. Try using something real small but hard along with a small hammer to move the tip in the clock-wise (CW) direction. Don't beat it, just give it little "love" taps. I'm betting that this will knock it loose and you will be able to remove it easily.
stuck set screw eric8221 Plumbing 3 03-25-2011 05:04 PM
Stuck Screw IceTreay General DIY Discussions 11 09-09-2010 02:56 PM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 03:17 PM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 11:47 PM
Stripped Phillips Head Lamurph5 Carpentry 24 01-21-2009 01:01 PM
