-   -   Riding Lawnmower clutch/brake whining (http://www.diychatroom.com/f2/riding-lawnmower-clutch-brake-whining-25519/)
ddodge 08-20-2008 09:46 PM
New member ... Great site! Got a Craftsman 16 horse riding lawnmower running that has been sitting a couple of years. When I put it in forward or reverse the clutch/brake makes a noise. If I put slight pressure on the clutch/brake it stops the noise. Any suggestions on the fix.
Thanks for any help.
Brik 08-21-2008 08:38 AM
Just a guess - Check for debris around the belts and pulleys. If there is none try changing the belts. 90% if issues on my rider are fixed with new belts. Maybe that's an exaggeration but belts are a common wear item.
ddodge 08-21-2008 08:57 AM
Thanks Brik, that could very well be the problem. The mower sat for years outdoors. Had quite a bit of dirt and debris in and around it. It looks like the previous owner tried to work on it and gave up. The problem was simply a clogged fuel line issue. After I found the clog, put new fuel lines and cleaned the carb It started right up. A half days work and my dad has a free, very good backup mower. It might even be a better mower than the newer one. It's bigger anyway.
Thanks for the help
Brik 08-25-2008 08:47 AM
Thats funny - I got my rider on free-cycle and it is exactly as you describe yours! It didn't run when I got it. New fuel lines and a battery and it started up. I then replaced the plugs, oil filter, fuel filter, fresh gas, etc. I also replaced the belts and blades. I am using it as a trail mower so I am beating the heck out of it. I have had to replace the PTO to deck belt a few times due to fast wear caused by mowing really high stuff and jamming blades on roots, rocks and stumps. Yikes! But heck, it was 'free'. next up is replacing the main drive belt which is a little involved but the mower drives much slower than it should. Good luck
