Ridge Vents - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-04-2008, 10:23 PM   #1
Smile
Ridge Vents
Guys and Gals I'm going to put up a new roof. And the contractor doing it for me wants to install ridge vents? Are they worth it? Do they help with insulation and air circulation? Or are they just a waste of time and money?
Tdoggy187 is offline   Reply With Quote
Old 02-04-2008, 10:50 PM   #2
you need vents
amdspitfire is offline   Reply With Quote
Old 02-05-2008, 05:38 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Ridge vents are about air circulation and roof temparature consistency.
YES, you need to have the ridge vents installed. In my area, it is REQUIRED by building code. They are fully functional and act as "exhaust venting" when they are working along with "intake venting" (like eave vents)
Information Links:
http://www.roofhelp.com/ventilation_main.htm
http://www.owenscorning.com/around/v...ofandattic.asp
http://www.naturalhandyman.com/iip/i...fattfan3a.html
- Build Well -
Old 02-05-2008, 09:49 PM   #4
Thanks for this great info :-) Much appreciated!!!
Old 02-06-2008, 06:17 AM   #5
It really cracks me up; all the contractors out there that "tell" people what they need, rather than taking the time to "explain" to them "what" & "why".... they need an installation or a certain course of repair.
FWIW:
I always take the time to try and explain to home owners why they need to do something, when an issue arises or is discovered. I carry a camera, with a large pixel display screen, so as I am explaining, I can even show them the pictures of the issue (that I took), while on their roof, in their attic, in their crawl space, etc.
I also like to keep diagrams in my file case, pertaining to roof ventilation, ice dams, drainage, etc. - so as to help educate people on how/why/what needs to be done....
Lastly, I feel it also clearly shows them, that there is a problem (if there is one), and that I am not attempting to sell them a repair or service that they do not need.
- Build Well -
Old 02-06-2008, 07:15 AM   #6
Rewards Points: 6,652
As soon as the vents where installed on our roof (only two vents on either side, and two windows (70+ y/o Bungalow), you could feel the difference when you opened the attic access. Our Roofing contractor repaired wood along the front of the roof where the Gutters are, due to last person that did the roof, did a hack job.
I have a whole library of pictures from it showing how bad it was, when the Roofing material was ripped off to prep the roof.
Old 02-07-2008, 10:48 PM   #7
I wished you lived near me AtlanticWB Construction.... I'd have you do the job :-)
low-slope roof and leaky ridge vent downers Roofing/Siding 15 02-21-2008 11:35 PM
sagging roof, rotten ridge board sonoflee Roofing/Siding 6 01-29-2008 06:12 PM
Ventilating Roof with no ridge? NateHanson Roofing/Siding 7 12-30-2007 04:33 AM
sofit vents + gable end vents no ridge vent mattg1970 Roofing/Siding 5 10-18-2007 09:47 AM
Losing aggregate from asphalt shingle ridge bkspero Roofing/Siding 8 07-19-2007 09:40 PM
