Reversing A Fiberglass Door? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-17-2009, 11:57 AM   #1
Reversing a fiberglass door?
Hi,
We are considering buying two used fiberglass doors at a local ReStore to replace our existing double doors. Both of the doors are hinged the same way, so one will need to be reversed.
Two questions:
1) is it possible to trim fiberglass doors so that they will fit in the existing doorway, or would it be better to re-hang the doors?
2) is it possible to remove a lock set from a fiberglass door and fill in the holes - and have it look like nothing was there?
3) Bonus question: anything else that I'm not thinking of?
Thanks,
Jon
JonL is offline   Reply With Quote
Old 11-17-2009, 05:47 PM   #2
Rewards Points: 5,336
The doors don't modify well if at all without looking like crap. Filling in holes in fiberglass requires a skill set so it doesn't look botched. Wood doors are better suited to the things you want to do.
Ron
Old 11-18-2009, 06:31 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
In addition to the lockset bore, the bevel on the edge of one door will be wrong. That will leave you with some really odd gaps at the hinge edge and the latch edge of the door.
Old 11-18-2009, 06:32 AM   #4
I agree. Trying to retrofit doors not made for that opening usually ends with bad looking doors and the energy efficiency goes way down. Don't skimp on a double front door setup, get a prehung unit.
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 03:19 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
