Reversing Deck Boards - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-22-2007, 05:11 PM   #1
Rewards Points: 150
reversing deck boards
I have a very large deck old but sturdy. The boards topside are splintering and old with weather cracks. One day I noticed the under sides were in beautiful shape. I know it sounds cheep!! but I'm looking at $1,500.00 bucks to replace them. Has anyone out there had experience at reversing there deck boards?
deck hand
deck hand is offline   Reply With Quote
Old 08-22-2007, 07:05 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Yup
Not my own, but have done it for others
Almost not worth the effort, it depends on how they were originally attached, and how well they are still attached
Takes more time then just demo-ing, as you must be really careful
Same with re-assembly
Also, your finish options can be limited depending on what you've got
If you have a good candidate, it can come out well and save you some bucks in materials
slickshift is offline   Reply With Quote
Old 08-22-2007, 07:39 PM   #3
joed's Avatar
Rewards Points: 12,442
Done it. You need to be careful removing them. Count on damaging some and needing a few new boards. Should be easier if they were screwed down.
Old 08-22-2007, 11:55 PM   #4
Deck Staining Pro
bigchaz's Avatar
The more splintering and cracks you have the harder it will be. Make sure you get a good nail puller instead of prying the whole board up
Charlie Soden
Apex DeckSavers
NC Deck Powerwashing, Deck Cleaning and Staining
"Bringing New life to Old Wood"
bigchaz is offline   Reply With Quote
Old 08-23-2007, 06:03 AM   #5
Agent 000
SecretSquirrel's Avatar
Typically the deck boards are installed crown up / cup down. Just keep an eye out for any cupping as you flip them and replace if necessary. You don't want to allow any water a place to accumulate. Although this may be a non-issue due to the age of the deck and the boards may have flattened out by now.
SecretSquirrel is offline   Reply With Quote
Old 08-23-2007, 09:00 AM   #6
Rewards Points: 150
Thanks this is my next project
Thanks for reminding me about the cup's I had forgotten about this!
These are all 20 ft's.
Deck hand
Old 08-24-2007, 10:51 AM   #7
Mod / ArchiBuilder
Cole's Avatar
I have done it and will not do it again.
To me it is too much trouble. If a professional was charging you to do it, it would be more money to reverse them, then to put new ones on.
Cole is offline   Reply With Quote
Old 08-24-2007, 12:39 PM   #8
Rewards Points: 150
reversing deeck boards
Thanks I must think about this again
Deck Hand
Old 08-24-2007, 02:05 PM   #9
Mod / ArchiBuilder
Cole's Avatar
Deck Hand
It might not be a lot more money, but I would charge you a little more for the extra work.
Are the boards screwed or nailed?
Old 08-24-2007, 06:21 PM   #10
Rewards Points: 150
deck boards
I'm a do it your self in Mich.
Deck hand
Old 08-24-2007, 08:54 PM   #11
Mod / ArchiBuilder
Cole's Avatar
Deck hand
Oh I know, I was just giving you a little more info.
If the funds are not available to buy new decking, I would reverse the current ones in a heartbeat. It just takes a little longer but if you are a diyer, time is not something you will have to be worried about.
Are the current ones screwed or nailed?
Old 08-25-2007, 06:10 AM   #12
Rewards Points: 150
The current boards are nailed, but they will come up easy
I all ready tried one.
Also if I have a hard one I have a garage floor jack that will lift five ton, so with this I can pry up the boards with no problem.
After this is all re installed I plan on renting a flat floor sander and sand the whole deck give it a coat of a good stain. What is so good is the deck is square, no angle cuts
deck hand
Old 08-25-2007, 08:01 AM   #13
slickshift's Avatar
Be sure to set the screws/nails below the wood level
Those sanders don't like metal too much
Old 08-25-2007, 10:38 AM   #14
Mod / ArchiBuilder
Cole's Avatar
deck hand
Sounds like a plan! If they are nailed, I dont see any problems that you will have.
BTW- When I was talking about more money for reversing them, I was talking about them being screwed down and having to take all screws out, which means a ton of work.
Good Luck!
Old 08-27-2007, 10:24 PM   #15
Deck Staining Pro
bigchaz's Avatar
good luck renting a floor sander if you let them know it is for a deck
you are sanding hardwood floors if you catch my drift
and be careful with those things. They can sand a hole right through the deck in no time. Use rough grit. 60 or courser
Charlie Soden
Apex DeckSavers
Issues with Trex Deck TrexConsumer Building & Construction 43 01-29-2010 12:14 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 07:12 PM
diagonal deck boards boots Carpentry 1 03-09-2007 08:15 PM
Cedar Deck boards Outbacker Painting 2 03-04-2006 01:12 PM
Deck repair/refinishing asdenyer Landscaping & Lawn Care 1 02-21-2005 10:32 AM
