Reverse Osmosis Setup - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-29-2008, 11:45 AM   #1
Reverse Osmosis setup
I would like to install a 6 stage RO system in my home and am wondering if I can supply more than one outlet with the system. I would like to install it in the furnace room in the basement and have an RO tap in my bathroom, kitchen, and also feed the refrigerator water dispenser.
I suppose the longest run of line would be about 20 feet. Will the system have enough pressure to supply all 3 outlets as is or is there something else I would have to do like build a manifold, etc?
billybarty is offline   Reply With Quote
Old 05-30-2008, 09:15 AM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
I would not feel good about feeding so much, so far. The most I have ever done was a tank in the basement feeding the sink faucet and water line to the frig. The longest run (frig) was about 12'. The pressure was at the absolute minimum. Actually, the auto ice maker tray would not completely fill so you had about 5/8 of an ice cube.
While it's an additional expense AND you need an electrical hookup, you can look at a booster pump. After a quick Google, here's an example:
http://www.waterfiltersonline.com/pumps.asp
Good luck
Angus
My Albums
angus242 is offline   Reply With Quote
home theater setup cannouu Electrical 5 04-09-2008 06:01 AM
Reverse Wiring (Hotwiring), Penny in Old Fuse Box rlmarr Electrical 14 03-28-2008 05:42 PM
Is this a 120V setup? twilightcall Electrical 42 01-07-2008 06:48 PM
how to replace, or maybe swap, this odd doorbell setup joeyboy General DIY Discussions 7 12-16-2007 12:53 PM
Best setup for cape cod walker45 HVAC 2 12-06-2006 05:20 PM
