Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 06-17-2012, 12:57 PM   #16
Average Joe/ex-Navy IC3
gregzoll's Avatar
"Reverse Cube Tap"
Originally Posted by jschaben
Hi Gregg- I'm not sure that would work for him. The way I read his requirement is that he needs to selectively direct one of two inputs to a single output. I admit I didn't didn't read the description all that closely but it looked to have only one input.
What they are wanting to do, is what the gear I posted is used for, when it comes to stage lighting. They just want to do it in a hack sort of way, which can lead to disaster.
Unless you have a relay or some type of protection built into your circuit, there is nothing stopping a person from walking over and flipping on the other power switch.
If they want something more robust, they can go with a lighting controller http://www.pssl.com/Lighting-Control
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
The Following User Says Thank You to gregzoll For This Useful Post:
abcde123 (07-02-2012)
Old 06-17-2012, 02:18 PM   #17
jschaben
"Reverse Cube Tap"
Hi Gregg - I yield to your expertise, I've never done stage lighting. That double pole double throw switch is essentially a manual version of the relay you are referring to.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
The Following User Says Thank You to jschaben For This Useful Post:
Old 06-17-2012, 03:21 PM   #18
gregzoll's Avatar
"Reverse Cube Tap"
No, it is not. Unless the OP install is permanent, which is doubtful, a good setup is not going to use light switches as controllers. After a while, you start introducing noise into your system, when the contacts of the light switches start getting dirty.
I have seen setups that they have basically built a panel with a bunch of light switches controlling a lighting circuit that was just a bunch of outlets. When you see how they did it, it shows how cheap the person that did it actually is.
Old 06-18-2012, 01:51 PM   #19
"Reverse Cube Tap"
Buy 2 lights, or make sure your insurance is up to date!!!
There is no safe way to do this, which is why you can't buy these parts! One light with 2 male plugs is bad ANY way you try to power it! People don't generally understand power flows both ways. Turn one on and the other will become hot as well. You'd needs a custom made box with some relays and other parts. The light only gets power from one outlet and switch. The other outlet/switch would simple trigger a couple relays to pass the main power in thru a flasher relay.
I also do "stage lighting" at a rather high level and the first box linked wouldn't do anything helpful, its a box of relays. He'd get the same effect with the double throw switch. Also with a suicide plug you don't always get 240v. In the same room he'd probably still only get 120v. There are safe ways of combining power sources. We do this for very high level events so we have true redundant uninterruptible power.
Buy 2 lights!
Mikelite80 is offline   Reply With Quote
The Following 2 Users Say Thank You to Mikelite80 For This Useful Post:
abcde123 (07-02-2012), jbfan (06-18-2012)
Old 07-02-2012, 11:26 PM   #20
Lightbulb
"Reverse Cube Tap"
Thanks for the advice all, it appears my method of achieving this effect was... misguided to say the least. To clarify a few things the first control box listed is half of the function i needed, and this is a setup intended for mobile use as part of a DJ rig. I ended up with this:
http://www.americandj.com/ProductDet...temNumber=1600
system, which includes a chaser pack with steady on modes (and also includes dimming and DMX abilities useful for future upgrades). I was originally thinking simply: 2 functions, 2 control means, hence two plugs, but I can see where this could quickly turn into something troublesome ( 120v + 120v = 240v = BAD; unplugged hot male plug = BAD, guessing this is where you guys got the term "suicide cord" from...)
In any case thanks for all the help!
abcde123 is offline   Reply With Quote
Tags
cube tap, electrical, help!, lighting, power
Better kids room option: bookshelf and drawers or cube organizer (pic) thebrandnewguy Interior Decorating 9 01-17-2012 09:36 AM
Ice cube maker on frig is not working ABROWN2556 Appliances 0 12-03-2011 01:45 PM
Ice cube Flatteal Off Topic 11 08-26-2011 11:17 AM
Ice Cube Odor rjordan393 Appliances 5 07-31-2011 12:12 PM
Ice maker makes 1 cube at a time??? Mary1 Appliances 7 05-19-2011 09:53 PM
