"Reverse Cube Tap" - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-16-2012, 09:10 AM   #1
Question
"Reverse Cube Tap"
I'm looking for a "reverse cube tap," unfortunately I seem to be unable to find this at the store. I effectively need a device that will combine 2 male wall plugs into 1 female plug so that I can power a lamp from either of 2 sources. Any idea where I can find such a device or if not then how to go about doing this better?
Thanks!
abcde123 is offline   Reply With Quote
Old 06-16-2012, 09:15 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 336
Ayuh,... Ya mean like This,..??
The Following User Says Thank You to Bondo For This Useful Post:
abcde123 (06-16-2012)
Old 06-16-2012, 09:17 AM   #3
close...
not quite, I have a bunch of those
I need the OPPOSITE of that, one that takes 2 or more male plugs (prongs sticking out) and combines it to one female plug (outlet holes).
I want to plug 1 lamp into 2 outlets so I can turn it on by applying power to either.
Old 06-16-2012, 09:24 AM   #4
Bondo's Avatar
Rewards Points: 336
Ayuh,... That'll be the potential cause of burnin' yer house down, if those circuits are on different breakers...
There's a reason ya can't buy what yer lookin' for...
The Following 4 Users Say Thank You to Bondo For This Useful Post:
abcde123 (06-16-2012), BigJim (07-03-2012), gregzoll (06-16-2012), oh'mike (06-17-2012)
Old 06-16-2012, 09:27 AM   #5
i see the potential hazard but i never intend to turn on both plugs at once so should be no problems there. The purpose is for a stage lighting system, so I can plug some parcans (lights) to a chaser pack and a direct wall switch, so i can use either source at will (flash to music or steady on) without plugging and unplugging the lights from source to source all night. If this is a dangerous solution, is there a better method? (note that I would generally power both source plugs from the same extension cord, split with a "normal" cube tap as pictured above or a power strip, so they should stay on the same leg.
Old 06-16-2012, 09:29 AM   #6
thats what im looking for
Old 06-16-2012, 09:42 AM   #7
is there no simple/safe/cheap way to achieve this? need 4 of them...
Old 06-16-2012, 09:43 AM   #8
Household Handyman
Rewards Points: 1,408
I'll admit that I don't know everything, and am forgetting more each day, but--that yellow "reverse cube trap" in the photo appears that it would not work with a normal duplex outlet found in home. Note that both of the neutral blades are side-by-side. I don't think I have ever seen a duplex receptacle which would be side-by-side. All the one's I have seen are "over-and-under" type. I still see a problem with this one: IF the duplex receptacle was split to the each outlet were on a different circuit, then you plugged this into a receptacle, which it would fit, you would have a cross-over of the electrical feeds. Not a good thing.
The Following User Says Thank You to Thurman For This Useful Post:
Old 06-16-2012, 09:51 AM   #9
note that that picture is a photoshop by me to illustrate what i need. The intent I have is to plug one of those plugs into a flasher pack that flashes a light on and off, and the other into a switched outlet that I can control directly. Yes if both come on at once bad things could happen ,but I would only turn the directly switched outlet on when the chaser is off. Both plugs would be used with extension cords so the exact configuration of the blades shouldn't be an issue.
Old 06-16-2012, 10:45 AM   #10
Old School
Willie T's Avatar
I want to keep an open bucket of gasoline in the center of my living room. I don't intend to ever use open flames near it, but.......
Willie T
The Following 2 Users Say Thank You to Willie T For This Useful Post:
abcde123 (07-02-2012), gregzoll (06-16-2012)
Old 06-16-2012, 10:26 PM   #11
jschaben
Rewards Points: 502
If I got the picture of what you want to do, you might wire an outlet controlled by a double pole double throw swith. They ain't cheap
http://www.amazon.com/Leviton-1282-M.../dp/B0033PSG5A
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
The Following User Says Thank You to jschaben For This Useful Post:
Old 06-16-2012, 10:40 PM   #12
Rewards Points: 6,652
Close enough to a Bill Engval reference for me.
The Following User Says Thank You to gregzoll For This Useful Post:
Old 06-16-2012, 10:41 PM   #13
So, basically you want a Suicide cord. You have to make them yourself, but again not wise, since if both outlets have power, you then end up with 240 volts. For stage lighting, they make controllers and dimmer packs for a reason.
Old 06-16-2012, 10:43 PM   #14
It would actually be easier for the OP to just get one of these http://www.pssl.com/American-DJ-SC8-...Control-System It is only a hundred bucks, and one of the most basic setups out there.
Old 06-17-2012, 10:57 AM   #15
jschaben
Rewards Points: 502
Hi Gregg- I'm not sure that would work for him. The way I read his requirement is that he needs to selectively direct one of two inputs to a single output. I admit I didn't didn't read the description all that closely but it looked to have only one input.
John Schaben
Tags
cube tap , electrical , help! , lighting , power
Better kids room option: bookshelf and drawers or cube organizer (pic) thebrandnewguy Interior Decorating 9 01-17-2012 09:36 AM
Ice cube maker on frig is not working ABROWN2556 Appliances 0 12-03-2011 01:45 PM
Ice cube Flatteal Off Topic 11 08-26-2011 11:17 AM
Ice Cube Odor rjordan393 Appliances 5 07-31-2011 12:12 PM
Ice maker makes 1 cube at a time??? Mary1 Appliances 7 05-19-2011 09:53 PM
