-   -   "Reverse Cube Tap" (http://www.diychatroom.com/f2/reverse-cube-tap-147224/)
abcde123 06-16-2012 08:10 AM
"Reverse Cube Tap"
I'm looking for a "reverse cube tap," unfortunately I seem to be unable to find this at the store. I effectively need a device that will combine 2 male wall plugs into 1 female plug so that I can power a lamp from either of 2 sources. Any idea where I can find such a device or if not then how to go about doing this better?
Thanks!
Bondo 06-16-2012 08:15 AM
Ayuh,... Ya mean like This,..??
http://www.allelectronics.com/mas_as...0x150-7544.Jpg
abcde123 06-16-2012 08:17 AM
close...
not quite, I have a bunch of those
I need the OPPOSITE of that, one that takes 2 or more male plugs (prongs sticking out) and combines it to one female plug (outlet holes).
I want to plug 1 lamp into 2 outlets so I can turn it on by applying power to either.
Bondo 06-16-2012 08:24 AM
Ayuh,... That'll be the potential cause of burnin' yer house down, if those circuits are on different breakers...
There's a reason ya can't buy what yer lookin' for...
abcde123 06-16-2012 08:27 AM
i see the potential hazard but i never intend to turn on both plugs at once so should be no problems there. The purpose is for a stage lighting system, so I can plug some parcans (lights) to a chaser pack and a direct wall switch, so i can use either source at will (flash to music or steady on) without plugging and unplugging the lights from source to source all night. If this is a dangerous solution, is there a better method? (note that I would generally power both source plugs from the same extension cord, split with a "normal" cube tap as pictured above or a power strip, so they should stay on the same leg.
abcde123 06-16-2012 08:29 AM
http://i48.tinypic.com/10pd1f4.png
thats what im looking for
abcde123 06-16-2012 08:42 AM
is there no simple/safe/cheap way to achieve this? need 4 of them...
Thurman 06-16-2012 08:43 AM
I'll admit that I don't know everything, and am forgetting more each day, but--that yellow "reverse cube trap" in the photo appears that it would not work with a normal duplex outlet found in home. Note that both of the neutral blades are side-by-side. I don't think I have ever seen a duplex receptacle which would be side-by-side. All the one's I have seen are "over-and-under" type. I still see a problem with this one: IF the duplex receptacle was split to the each outlet were on a different circuit, then you plugged this into a receptacle, which it would fit, you would have a cross-over of the electrical feeds. Not a good thing.
abcde123 06-16-2012 08:51 AM
note that that picture is a photoshop by me to illustrate what i need. The intent I have is to plug one of those plugs into a flasher pack that flashes a light on and off, and the other into a switched outlet that I can control directly. Yes if both come on at once bad things could happen ,but I would only turn the directly switched outlet on when the chaser is off. Both plugs would be used with extension cords so the exact configuration of the blades shouldn't be an issue.
Willie T 06-16-2012 09:45 AM
I want to keep an open bucket of gasoline in the center of my living room. I don't intend to ever use open flames near it, but.......
jschaben 06-16-2012 09:26 PM
If I got the picture of what you want to do, you might wire an outlet controlled by a double pole double throw swith. They ain't cheap
http://www.amazon.com/Leviton-1282-M.../dp/B0033PSG5A
gregzoll 06-16-2012 09:40 PM
Close enough to a Bill Engval reference for me.
gregzoll 06-16-2012 09:41 PM
So, basically you want a Suicide cord. You have to make them yourself, but again not wise, since if both outlets have power, you then end up with 240 volts. For stage lighting, they make controllers and dimmer packs for a reason.
gregzoll 06-16-2012 09:43 PM
It would actually be easier for the OP to just get one of these http://www.pssl.com/American-DJ-SC8-...Control-System It is only a hundred bucks, and one of the most basic setups out there.
jschaben 06-17-2012 09:57 AM
Hi Gregg- I'm not sure that would work for him. The way I read his requirement is that he needs to selectively direct one of two inputs to a single output. I admit I didn't didn't read the description all that closely but it looked to have only one input.:)
