Reuse Or Remove Contact Stuff From Back Of Mirror - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-19-2012, 03:23 PM   #1
Rewards Points: 178
reuse or remove contact stuff from back of mirror
How do I reuse the contact stuff on the back of this mirror (attached/inline) so I can re-mount it back on a wall? If I can't reuse it, how can I remove it so I can re-mount it on a wall?
anuvanoob is online now   Reply With Quote
Old 10-19-2012, 03:52 PM   #2
Rewards Points: 178
Another view of it (attached/inline)
Old 10-19-2012, 03:56 PM   #3
bbo
looks like gunther mirror mastic.
its permanent. surprised you got that off in one piece.
truthfully, I would just order another piece of glass form a local glass shop.
you could just put mirror mastic in the areas that are clean right now to reuse it.
bbo is offline   Reply With Quote
Old 10-19-2012, 03:57 PM   #4
Rewards Points: 13,300
Trying to remove it will take the silver coating on the back.
Mirrows are cheap. Concider buying a new one.
Old 10-19-2012, 04:06 PM   #5
Rewards Points: 178
I understand mirrors are cheap and I've considered just buying a new one when I got frustrated, but I'd like to move forward anyway to help build up my handyman skills. What about framing it and mounting it that way? Is that possible?
Old 10-19-2012, 04:15 PM   #6
bbo
sure you can.
as also mentioned, you can use more gunther mirror mastic in spots not already used. you'd have to make it a bit thicker though.
I'd still just get a new mirror. like mentioned, they are cheap and you can get em delivered cut to the size you need.
and if you do get a new mirror, seal the edges and and any cutouts.
Old 10-20-2012, 10:40 AM   #7
Rewards Points: 222
if the mirror is in good shape, i would reuse in. why spend money for something that you already have.
Fix'n it is offline   Reply With Quote
Old 10-20-2012, 02:31 PM   #8
jschaben
Rewards Points: 502
Framing sounds like a good idea. I would back it up with foam board/cardboard/plywood/whatever with holes cut out for the blobs of glue. Just to give it even support all around.
Heat, like from a hair dryer, may soften the stuff enough to get some off. I think the guys are right, if you try to pry or scrape it off, the silvering may come along with it.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 10-20-2012, 04:56 PM   #9
Too Short? Cut it Again!
It is too big to frame and hang safely without some support from framing wire unless you put a bunch of anchors in the wall. You will soon be up to the cost of a new piece of mirror glass. New mastic where there is none now will work so long as, as mentioned, you heap it on thicker/deeper than what is there now. You will destroy the backing trying to get what is there off.
window screens how to remove and put back twinkenator Building & Construction 5 07-07-2010 12:49 PM
Removing wall sticking goop from back of mirror. Terry383 Interior Decorating 5 06-29-2010 08:36 PM
Hanging a Heavy Mirror frapha1 General DIY Discussions 6 01-03-2010 12:21 PM
Most effective way to remove cut back? bigbavarian Flooring 2 10-01-2009 10:55 PM
How to remove these 'pads'? Solvents? Mechanically? (Pads on mirror!) joeyboy General DIY Discussions 11 08-04-2007 07:01 PM
