-   -   reuse or remove contact stuff from back of mirror (http://www.diychatroom.com/f2/reuse-remove-contact-stuff-back-mirror-160569/)
anuvanoob 10-19-2012 02:23 PM
1 Attachment(s)
How do I reuse the contact stuff on the back of this mirror (attached/inline) so I can re-mount it back on a wall? If I can't reuse it, how can I remove it so I can re-mount it on a wall?
Attachment 59088
anuvanoob 10-19-2012 02:52 PM
1 Attachment(s)
Another view of it (attached/inline)
Attachment 59089
bbo 10-19-2012 02:56 PM
looks like gunther mirror mastic.
its permanent. surprised you got that off in one piece.
truthfully, I would just order another piece of glass form a local glass shop.
you could just put mirror mastic in the areas that are clean right now to reuse it.
joecaption 10-19-2012 02:57 PM
Trying to remove it will take the silver coating on the back.
Mirrows are cheap. Concider buying a new one.
anuvanoob 10-19-2012 03:06 PM
I understand mirrors are cheap and I've considered just buying a new one when I got frustrated, but I'd like to move forward anyway to help build up my handyman skills. What about framing it and mounting it that way? Is that possible?
bbo 10-19-2012 03:15 PM
sure you can.
as also mentioned, you can use more gunther mirror mastic in spots not already used. you'd have to make it a bit thicker though.
I'd still just get a new mirror. like mentioned, they are cheap and you can get em delivered cut to the size you need.
and if you do get a new mirror, seal the edges and and any cutouts.
Fix'n it 10-20-2012 09:40 AM
if the mirror is in good shape, i would reuse in. why spend money for something that you already have.
jschaben 10-20-2012 01:31 PM
Framing sounds like a good idea. I would back it up with foam board/cardboard/plywood/whatever with holes cut out for the blobs of glue. Just to give it even support all around.
Heat, like from a hair dryer, may soften the stuff enough to get some off. I think the guys are right, if you try to pry or scrape it off, the silvering may come along with it. :)
user1007 10-20-2012 03:56 PM
It is too big to frame and hang safely without some support from framing wire unless you put a bunch of anchors in the wall. You will soon be up to the cost of a new piece of mirror glass. New mastic where there is none now will work so long as, as mentioned, you heap it on thicker/deeper than what is there now. You will destroy the backing trying to get what is there off.
