Retrofit Drawer Slides Help! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-02-2013, 08:46 AM   #1
Retrofit drawer slides help!
I’m replacing my old kitchen drawer side mounted rollers that are worn (built in the 90s). I was looking to use the KV 8400 on some drawers and 8450 soft close on others. However I discovered the drawer boxes are 21” and the cabinets are 24”. I’ll have to use front and rear brackets for most of the slides to mount them. This is my first time doing this type of project but I’m pretty handy.
How will I mount the slides with a 3 inch gap? Do I get 21”, 22” or 23” slides? I want the drawer to open the full length of drawer. I know the slide length should be the length of the drawer box but what should I do in this case with a 3” gap plus use soft close slides on some drawers. Should I consider an overtravel slide in this case vs full length? Do I need to mount a wood strip in the back to make up the gap? Any help would be great to plan my attack!
Jvdirt is offline   Reply With Quote
Old 09-02-2013, 09:15 AM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Jvdirt View Post
kitchen drawer side mounted rollers that are worn.
I was looking to use... However I discovered...
Any help would be great...
Find a source for more of the SAME drawer slides you have now.
Old 09-02-2013, 10:31 AM   #3
How come? Too much work?
Old 09-02-2013, 04:34 PM   #4
Actually I have KV 1300 slides currently which are 3/4 ext. So I would expect the 8400 to be not too much additional work to replace..?
DTC Drawer Slides from China BrewinBend Kitchen & Bath Remodeling 5 08-22-2013 10:37 AM
replacing kitchen drawer slides gerrybinder Carpentry 7 01-05-2013 09:08 AM
Desperate! Drawer clearance for undermount slides LCCamel Carpentry 1 07-20-2012 08:59 AM
How do you measure drawer slides? Total Tool General DIY Discussions 10 12-29-2011 12:03 AM
Exterior Drawer SLides Peter G Carpentry 2 06-17-2009 05:16 PM
