Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-23-2007, 03:35 PM   #1
Retractable Awning Installation
Has anyone installed a motorized 16ft awning to a 2x8 header? I had a previous header installed where I had a wood awning. It was 2x6. It was removed. Siding was installed around this header. I want to replace the header with a 2x8. The header will be of course mounted to studs. Do the awning brackets need to be mounted through the header board into the studs or would mounting them directly to the header board be enough?
Or, would replacing the section of siding and mounting the awning directly to the studs be a better option?
Please let me know your thoughts.
jerome8283 is offline   Reply With Quote
Old 09-23-2007, 03:52 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Unless the awning is larger then the 2x6 header, you should be okay mounting the awning to the existing. Now if you change it out, you will have to either recover with the vinyl siding to keep the header from rotting, or use a pressure treated piece of lumber.
gregzoll is online now   Reply With Quote
Old 09-23-2007, 04:00 PM   #3
Yes, the brackets are slightly larger then 6". I do plan to cover the 2x8 with vinyl covering.
Inducer installation / modification ... caseywa HVAC 26 12-06-2010 02:50 PM
hanging an awning martin 1 Building & Construction 2 05-08-2007 08:59 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
